hilux diesel snorkel vibration
Submitted: Saturday, Nov 13, 2004 at 15:31
ThreadID: 17779 Views:5961 Replies:4 FollowUps:1
I have a 94 4runner 2.8 diesel with a safari snorkel. Having big problems with noise and viration.I have tried different inlet manifold and air box,only changed the RPM at which the vibration occured.I beleive it is caused by intake air pulsation.I have been to ARB and was told the only way to fix it is remove it or fit a turbo.Has any one found any other solutions without selling the car.
Reply By: GRAEME - Saturday, Nov 13, 2004 at 16:26
Have you got the foam filter thing in the inlet of the snorkel, you should have if it's non turbo. Make sure it hasn't rotted or slid down to the bottom if it was there.
Also make sure the bracket at the top isn't touching the A pillar.
Or do yourself a favour and fit a turbo;-)
AnswerID: 84229
Reply By: Davoe - Saturday, Nov 13, 2004 at 17:28
interestingly a guy posted ages ago about fitting a hiclone to his snorkal and the only benifit he got was a reduction in the vibration - that led to a few interested followups rather than the usual negative feedback about hiclones
AnswerID: 84234
Reply By: 80scruiser - Saturday, Nov 13, 2004 at 21:54
I see alot of these come through my work shop from car yards as far up as 2000 models and on.
The resignation in the air intake usually vibrates the left front park light loose. For car yard cars, I remove the light and secure it with silicone as it only has one screw and a snap style clip holding it. It only reduces the vibration and doesn't fix the underlying problem.
As soon as I find a solution I will put up a post. I think it is in the air intake ducting up inside the guard. I had a similar thing with my 80 series and when I fitted the snorkel I had to remove the ducting from inside the guard and thats where I found loose screws.
I would try removing the left inner splash guard and having a squiz inside the guard to see what you can find.
Best of Luck
AnswerID: 84261
Follow Up By: troy - Monday, Nov 15, 2004 at 17:25
The aerial was the cause of my vibration. The nut securing it to the body had vibrated off. Secure the aerial and all was sweet.
Also make sure that all the screws holding the snorkle are secure
Troy
FollowupID: 343224
Reply By: GO_OFFROAD - Sunday, Nov 14, 2004 at 17:04
Another thing to note is that if you dont drill the holes for the snorkel mountings as per the instructions, you may get vibration and noise transmitted through the snorkel from the stud rubbing on the fender.
AnswerID: 84309
