WIRING SECOND BATTERY
Submitted: Saturday, Nov 13, 2004 at 20:45
johno!
hi everyone i am hoping that someone can give me advise on wiring up my second battery.
i have a dual-cab hilux and wish to put my engel & second battery in the back tray.
this is my idea, run a 120 amp lead from the startermotor solanoid,to the second battery, then a 120 amp lead from the chassi to the second battery and put a isolator switch in the possitive lead.
from there hook up the engel, or should i come straight off the main battery terminals?
thankyou johno!
Reply By: Leroy - Saturday, Nov 13, 2004 at 20:59
Johno,
I'd get a redard isolator ($120) and mount that under the bonnet and run your -ve straight from your starter batt. to ensure a good earth. I ran 4AG cable ($5/m) which is not cheap and I put them in split plastic tube to protect the cables and then wrapped it with insulation tape to keep stones/dirt out also. I ran it from the engine bay to the chasis fixing with cable ties all the way along the chasis to
the tub then come up though a hole in
the tub. Make sure you get a rubber ring from Clark rubber or somewhere for the hole you drill.
Happy cold beer.....Leroy
Ps make sure you leave a bit of slack for the cable where it attaches to the chasis. The cab and tub moves on the chasis a bit.
84255
Follow Up By: Bonz (Vic) - Saturday, Nov 13, 2004 at 22:09
That'd be Redarc isolator
343073
Follow Up By: johno! - Sunday, Nov 14, 2004 at 11:01
hey thanks leroy your comments have been a great help, looking for the redarc now.
hope to have quiet a few cold ones! johno!
343091
Follow Up By: Leroy - Sunday, Nov 14, 2004 at 11:30
geez I thought I got all the spelling mistakes as I proof read a coupld of times!! c key is below the d key....c key is below the d key....c key is below the d key....
Leory
343093
Follow Up By: Bonz (Vic) - Sunday, Nov 14, 2004 at 12:49
That'd be Leroy (not Leory)
343094
Follow Up By: johno! - Sunday, Nov 14, 2004 at 20:19
hi leroy hope im not bothering you too much, i have one more question.
when i set up the isolator this way is it ok for me to charge the auxilary
battery in
the tub, straight from my generator without disconecting
anything and will that also charge the main battery aswell.
(short question will it charge in reverse).
thanks johno!
343130
Follow Up By: Leroy - Sunday, Nov 14, 2004 at 20:49
I'd recoment disconnecting the batt because I have seen the isolator stay on after I have turned off the ignition. So it could charge in reverse but it's not designed for that. Give Rearc a call. If you have to connect the gen to the battery it only takes 30 sec to disconnect the batt. Dont let the +ve touch anywhere incase the solenoid is still on. Use some of those batt terminals with the wingnuts to connect the cables and get an auto elec to crimp on the lugs as they have a big crimping tool to suit 4AG cable.
Leroy
Ps and full marks Bonz, youre on the ball!
343132
Follow Up By: johno! - Sunday, Nov 14, 2004 at 21:32
thankyou again for your advise, i will give redarc a call.
regards johno!
343140
Reply By: Billy - Saturday, Nov 13, 2004 at 21:02
Assuming vehicle is used daily, IMHO you do not need a second battery to safely run an Engel (of recent vintage). Run a 20A pos to the tray off battery, earth it local and run off that. Use a $20 Projecta Sure Start low voltage cutout in circuit. Power Pack backup is optional and recommended (regardless of Engel). Dual batt for most modern compressor fridges is an aftermarket industry self perpetuated conspiracy. Upgrade main battery if you really really feel the need to spend your cash.
Remember JMHO.
84256
Follow Up By: Member - Phil G (SA) - Sunday, Nov 14, 2004 at 08:05
Billy,
I agree with you but add the proviso that you need to be running your vehicle each day. People who stay put when camped, particularly in warm weather will still want a second battery.
343084
Follow Up By: johno! - Sunday, Nov 14, 2004 at 11:07
thankyou for your reply billy, but as phil g said, i will be going on a 4 month trip down to tassie and will be haveing extended stays, so really do need aux battery also have backup generator.
thankyou again johno!
343092
Follow Up By: Billy - Sunday, Nov 14, 2004 at 14:13
Johno, yes, you need one for sure. FYI, someone is selling Redarc isolators on ebay of late. Then again, 3 way Chescolds are going for around $400 on ebay too..but that's another story!!
Regds
Bill
343099
