Navara Suspension lift
Submitted: Sunday, Nov 14, 2004 at 21:59
jbellman
I'm after any info regarding lifting the
suspension on a 2002 STR Navara. I would like to go as high as possible and put the largest Cooper ST's on that can fit.
Have spoken to a fellow down south about putting coils in the rear and will most likely put ARB torsions on the front . Bu thow high can you go and what are the problems that arise.
This is the first IFS that I have played with , I've lifted mt Jeep 4" and that was pretty simple. I know I will loose some down travel but hope someone has done the homework .
Look forward to hearing from you .
john
Reply By: GO_OFFROAD - Monday, Nov 15, 2004 at 07:44
The thread on the top of the front shocks is long and you can space the shock down to get 1" of down travel back in the front, you may also need a bump stop spacer in the front to stop rubbing, but if you lose an inch of up travel with the spacer, you gain it in down travel by spacing the shock down and in the rear you can fit lift blocks between the leaf spring and diff, or fit longer shackles.
84375
