current drawn by dvd players at 12 volts
Submitted: Thursday, Nov 18, 2004 at 21:28
ThreadID: 17909 Views:2556 Replies:4 FollowUps:4
Folks, I want to run a small tv and dvd or vcr player off 12 volts. I know the little tv draws about 1amp because it has a 12 volt input and I've measured it.
Questions:
1. If a dvd or vcr requires 24 watts @ 240v (as stated on the rear panel), does this mean it will draw 2amps @ 12v?
2. If I operate said dvd or vcr via an inverter, what continuous power rating do I need on the inverter?
3. Does anyone know of a 12vdc dvd or vcr on the market (so that I can eliminate the need for an inverter)?
Thanks,
Rob.
Reply By: Member - Jimbo (VIC) - Thursday, Nov 18, 2004 at 21:45
Rob,
I have looked into this.
The inverter will draw about 0.8 amps on its own just running and then will draw the required power to run your appliances.
1. Yes that is right.
2. Get an inverter of at least 300 watts, the 150 watt jobs struggle with anything other than one appliance.
3. The cost of dedicated 12V appliances generally outweighs the cost of using conventional 240V appliances from an inverter.
Just my experience.
Jim
AnswerID: 84935
Follow Up By: Robbg - Thursday, Nov 18, 2004 at 23:33
Thanks Jim, another question comes to mind - will a quasi sine wave inverter do the job with appliances like a dvd or vcr or do I need a pure sine wave unit? It would also need to power a battery charger for digital camera batteries.
Rob.
FollowupID: 343597
Follow Up By: Member - Jimbo (VIC) - Friday, Nov 19, 2004 at 07:23
Rob,
I run a cheapo modified square wave job and it runs the laptop fine. Haven't tried it to charge batteries.
Jim.
FollowupID: 343608
Reply By: Member - Captain (WA) - Thursday, Nov 18, 2004 at 22:31
Hi Robbg
You can buy a DVD player that runs on 12V and is DIN size. Prices start from $150 and go to a small fortune. This typically is connected to a small LCD screen for in vehicle use. You can also buy 12V TV's with built in VCR's or DVD's.
I have an Orion 10" TV with builtin VCR player that runs on either 12V or 240V that I use in my van (I try to avoid using it, but great to occupy kids in adverse weather). I also have a 12V DVD player and roof mount LCD screen in my Patrol that enables long distance to be covered without to many "are we there yet" chorus's.
While many scoff at the thought of such electronic amusements for the kids, the reality is that it enables some big distances to be covered when one has a long way to go and unfortunatley hasn't the time to take their time. We still do all the "eye spy", colouring books, games etc... but also have the DVD as another tool to keep the kids amused. Hopefully one day it can be removed!
Captain
AnswerID: 84940
Follow Up By: Member - Jimbo (VIC) - Friday, Nov 19, 2004 at 07:26
Captain,
I agree whole heartedly with your sentiments about keeping kids occupied. On the 7 hour trip to and from Robe my son sat watching DVD's on the laptop and actually enjoyed the drive.
Vheers,
Jim.
FollowupID: 343609
Follow Up By: Member -Dodger - Friday, Nov 19, 2004 at 16:16
Hi Captain, I also run the same 10" TV VCR unit in my van off 12v but wanted more so I purchased an in dash Car AM/Fm/DVD radio player built it into the van and mounted a plug so that the video outlet could be connected to the TV. This allows the handbrake and I to watch a dvd when there is no tv available or the video cassettes have run out also there is the bonus of a long range radio to enjoy, or get the weather from.
All this when in use chews about 4amps from the battery. (In House) That is charged off solar, alternator from tow vehicle and 240v when it is available.
These Units are easily purchased on Ebay at very reasonable prices. Mine was $195 plus postage.
All works great.
Cheers Dodg.
FollowupID: 343690
Reply By: Tim HJ61 - Thursday, Nov 18, 2004 at 23:41
I'd agree with Captain and others re the 12v DVD's with small screens. I bought one with two screens, the DVD player and a game console for around $650. Plugs into ciggy lighter, low current draw, no need for an inverter and it's designed for in car use - protected from the vibration.
Three years ago when I was chasing this equipment, no one had even heard of it, now it's readily available.
I strap the screens onto the back of the front seats, and although they are small, the kids are not too far away and have never complained about the small size. The system allows them to play the DVD through either one or both screens, or play the DVD on one screen and the game console -(about 10 games inbuilt into the controller) on the other screen. All removable and can move between vehicles, or be set up outside for a movie show before bedtime if you're desperate.
With some sunscreens across the side windows and a towel between the buckets at the front, their headphones in, I didn't get a peep for hours when it was 43 outside and heading from Newman to Perth - not the most scenic country. My unit needed to be placed on an upturned stable table to stop it jumping tracks, but otherwise performed well.
Tim
AnswerID: 84950
Reply By: Member - Collyn R (WA) - Friday, Nov 19, 2004 at 10:20
Be cautious with modified square wave inverters. They will run a lot of things - but far from all. Xantrex (who make both those and sine-wave inverters) has a long list of appliances that will not run on other than sine-wave. Includes many electric razors, almost all laser printers, plus about 100 other things.
If you really know what you are doing then a modified square wave can save money - but unless you do it's better to spend more and be assured.
For what it's worth I designed and built my own big (2500 watt) modified square wave unit about 20 years ago - but I would not even think of using one nowadays.
Collyn Rivers
AnswerID: 84978
