60 series engine conversion
Submitted: Thursday, Nov 18, 2004 at 22:50
ThreadID: 17915 Views:8821 Replies:3 FollowUps:3
Hello out there I hope someone can help I have 1989 60 series landcruiser with a sad 2h diesel and I have found a 96 model 80 series (1hz) I think it is,at a good price has anyone out there done this conversion? I need to know whats involved I was told the engine mounts had to be changed the exhaust is on the oppsite side also wiring needs to be lengthened radiator outlets swapped over use my cutch and pressure plate and some type of spacer plate between the bellhouseing I have a turbo that I will put on the 1hz if any one has done this or knows someone who has any info I would be very greatfull as I dont know who to ask to get info for this conversion, hope someone can help thanks heaps Scott I can also be contacted at (fat666@exemail.com.au) Cheers
Reply By: ross - Thursday, Nov 18, 2004 at 23:14
Hi Scxott,I dont know of any oz sites that have a step by step but this one from a canadian60 owner is ok.
Remember that this landcruiser is LHD
http://forum.ih8mud.com/showthread.php?t=19578
AnswerID: 84948
Reply By: Davoe - Friday, Nov 19, 2004 at 10:57
put a 12ht in it much easier and more power. btw I own an hzj 75 with hj running gear so I can tell you the conversion can be done in reverse
AnswerID: 84987
Follow Up By: scott666 - Friday, Nov 19, 2004 at 11:56
Thanks Davoe your not the first person to tell me this, does the 12ht actualty have more power than a 1hz turbo? thanks for your reply cheers Scott
FollowupID: 343640
Follow Up By: Davoe - Friday, Nov 19, 2004 at 13:54
cant give you any figures but I think the 12ht is around 130kw undoubtatly a 1hz turbo makes more power (I thought you were talking about a standard 1hz) HOWEVER I believe the 12ht to be a better motor than a turbo 1hz as all info I have heard is that 1hz can suffer problems when turboed. The 12ht is not just a 2h with a turbo as it has other mods for it to reliably take a turbo. Check out the post above (I think) about landcruiser sahara turbo diesal (same motor) for reliability testimonials
FollowupID: 343662
Reply By: scott666 - Friday, Nov 19, 2004 at 14:25
Thanks Davoe I didnt know they had other changes on the 2ht I thought it was just a 2h with a bolt on turbo,it would be a lot less mucking around to fit a motor that will bolt straight in rather than go to all the trouble and stress plus expence of fitting the 1hz I will do some looking around and see what I can find, thanks for all of your input it does sound like the right advice, much appreciated Davoe thanks mate.Cheers Scott
AnswerID: 85024
Follow Up By: Davoe - Friday, Nov 19, 2004 at 16:02
hey! this q has been asked before by matt. Go to the search function type in matt, click on topic and body, then use the calender next to start date and click on 17/11/02 then same with end date - some good info
and yea there are definitly a few subtle differences to oil gallerys I believe and there is no edic motor. there is one for sale on ebay for 7k I dont know what they are worth but sounds heaps rich coz it has 300k
FollowupID: 343688
