hilux gearbox breather?
Submitted: Saturday, Nov 20, 2004 at 20:27
ThreadID: 17968 Views:5517 Replies:3 FollowUps:3
Evening all.
Can any one tell me where the gearbox & transfer breathers are on an 84 hilux diesel (5speed).
I removed the panel on the floor under the console, but nothing there, my manual does'ent have any pics of it, and I can't see anything obvious on the sides.
I changed the oil today and it had the old tell tale glug glug that
you get when the air can't get in quick enough to replace the oil, removing the filler plug stops this of coarse.
Hope somone can point me in the right direction.
Thanks in advance,
Nomad.
Reply By: Wisey (NSW) - Saturday, Nov 20, 2004 at 21:35
Hi Nomad
I have a 94 xcabDsl and the gearbox breather is in front (forward) of the gear shift on top of the box. I removed the console etc and could see it, wiggle it but couldn't access it if I wanted to clean or check.
With the glug,glug it sounds like it is struggling for air so if you do have one it could be blocked. Don't know of my transfer breather but I'll check it out for you.
Hope this helps.
Andy
AnswerID: 85186
Follow Up By: nomad - Saturday, Nov 20, 2004 at 22:15
Thanks wisey, but when i had the panel off the floor I put my hand right forward up to the bell housing, but still nothing, I want to clear it out so as not to cause any future problems, maybe mine is a different box, or something.
FollowupID: 343803
Reply By: Yeah Mate - Sunday, Nov 21, 2004 at 02:40
nomad
I have a 86 lux and it is the same, I recon the breathing is done through the shift levers as these are on sealed on the pivot point (ball area).
AnswerID: 85214
Reply By: madlee - Sunday, Nov 21, 2004 at 08:36
I had an 84 4runner,Ithink it might be closer to transfer case,can't really remember.The breather's construction is ametal cap clipped over the fitting,inside is a rubber disc held down onto the fitting by a spring.the design I believe is to let the out as it heats up,but to keep water out on rapid cooling.I have just looked at my work shop manual and it doesn't show a breather any where on the box or transfer case.So what you have experienced is normal, even if it had a breather it would do the same thing.The diffs will have breathers of the same construction as above
AnswerID: 85221
Follow Up By: nomad - Sunday, Nov 21, 2004 at 09:49
Thanks fellas, I think that the breathing through the stick is probably right, there is nothing resembling a conventional breather on top of the box.
The diff breathers are ok, I've extended them up under the bonnet, as is the standard practice, and they breath fine, my concern is, that when I took the drain plug out of my hot transmition, it had preasure in it.
Can only be a blocked breather, wish I could see one out of the car.
FollowupID: 343821
Follow Up By: madlee - Sunday, Nov 21, 2004 at 19:46
Being a mechanic,I haven't found very many 2wd cars with breathers on the transmissions.They wil build up pressure when hot,possibly upto 5psi.They will also do the glug glug until you remove the filler plug.I have been thinking during the day and I am pretty confident that the box or transfer don't have a conventional breather,because I went looking for them to raise their hieght.All the best
FollowupID: 343849
