Showers and hand throttles..the answer
Submitted: Saturday, Nov 20, 2004 at 22:58
ThreadID: 17973 Views:3022 Replies:5 FollowUps:12
Recently a question was asked regards a hot water system for a shower that wasnt getting hot enough and it was assumed the radiator flow was not enough to heat the water at idle and hence the person wanted ideas on a hand throttle so he could increase the revs.........read on.
It should have occurred to me earlier but the problem is that when using the heater hoses as the feed into the heat exchanger, there is no water at all flowing through those hoses unless the heater is actually turned on.........and the hotter you set the heater in the car..........the more water will flow through the hoses............so in a way you can actually use the car heater to regulate how hot your shower water is going to get.
Hope that helps.
Reply By: Member - Collyn R (WA) - Sunday, Nov 21, 2004 at 10:39
Could just be the radiator thermostat is staying open. I'd check that first.
Otherwise it's most probably that the heater is not sufficiently on.
Collyn Rivers
AnswerID: 85235
Follow Up By: Top Cat - Sunday, Nov 21, 2004 at 18:24
Yeah I offered that suggestion originally Collyn and got flamed for it..............lol.
FollowupID: 343842
Reply By: Member - JohnR (Vic) - Sunday, Nov 21, 2004 at 17:34
Top Cat it is good to work out that but even better to make sure you get the heater turned off again when you start the day and 35 degrees outside and not have the aircon fight just the heater...............
4.2 Nissans have the hand throttle too as well as the heater control. Good hose to reverse ends to the heat exchanger at the back of the engine on GUs too.
AnswerID: 85269
Reply By: Tim - Sunday, Nov 21, 2004 at 20:18
Yeah that person was me, I have done all that but I think the problem is my shower pump, as it pumps 10L/m it takes a hell of a lot of heat out of the system.
I did a bit of R and D today and to have a hot shower I need to run about 3000RPM. So I guess my showers will be quite inefficent. The price you pay to keep the girl happy!
Tim
AnswerID: 85287
Follow Up By: Top Cat - Monday, Nov 22, 2004 at 10:39
Ah........OK, yeah that makes sense mate.
The ones my brother and i made have about 5metres of thin copper tube coiled up inside the heat exchanger so the cold water has a fair way to travel.
We ran our pumps in such a way as to get 20litres over a 6 minute period.
However we could have shortened the time or increased the ammount of water or both if we wanted...........its just that that was how we did the testing.
Cheers.
FollowupID: 343897
Follow Up By: Michael ( Moss Vale NSW) - Monday, Nov 22, 2004 at 13:12
Hi Tim, Top Cat is correct, about 3 to 4 litres per minute is about all you will get for a 45deg shower, slow the flow to the shower with a ball valve and time 4 litres a minute, see what happens, What type of heat exchhange have you got?? Michael
FollowupID: 343921
Follow Up By: Tim - Monday, Nov 22, 2004 at 13:31
Its a helton, I went with them as they were able and willing to customise it slightly quite cheaply (building it with certain inlet and outlet points at a particular end with elbows to fit in the tiny amount of room I had).
Took a look at their website and they have some graphs for temp Vs flow rate and 10L/m is way higher then it can handle without recirculating. I can only pressume others would be the same.
Tim
FollowupID: 343926
Follow Up By: Michael ( Moss Vale NSW) - Monday, Nov 22, 2004 at 13:46
Hi Tim, I have a unit on my Gu 4,2 tdi, makes 48 deg at idle @ 3.3 litres a minute. Gu's are known for their cool running engine so these results are extremely good. At 3000 rpm it will take the skin off your back or will handle another liter or so per minute at the same temperature. If you have a petrol vehicle the results will be much better again and will support more flow through the showerhead. If you are serious about getting it to work at idle give me a buzz on 0438 26 01 57. best regards Michael.
FollowupID: 343927
Follow Up By: flappan - Monday, Nov 22, 2004 at 13:51
The shower on my Petrol GU actually runs to hot at idle , I need to find a way to cool it slightly.
Mine now runs with both water and coolant running in the same direction.
FollowupID: 343928
Follow Up By: Michael ( Moss Vale NSW) - Monday, Nov 22, 2004 at 13:59
Hi Flappan, is seems that some of the petrol engines do ok and some not, i suppose its a combination of engine water pump flow, temp the engine runs at and the efficiency of the exchanger. The coil type exchangers are of old technology, not a lot of the water that goes through them, actually contacts the coils. What flow through the showerhead are you running to get a "too'' hot shower? michael
FollowupID: 343929
Follow Up By: flappan - Monday, Nov 22, 2004 at 14:30
I'm not 100% certain to be honest.
I have a flowjet pump (the smaller brother of the shurflow pump) , what are they . . . 6 or 7 litres per minute ?
When I had one of those 12v DSE ones , water temp was fine (less water flow). One of the issues I have , is that I have a Ti Patrol with climate control, you dont have as an exact a temp , as say a slide control. I find , for example , that 28 on the CC , is too cold, 29 is too warm . . . just , 30 and 31 wont get near it.
I'm going to change to a system thats "T" ed off the main hoses with a seperate slide heater control. That way , I wont need to muck around with the CC controls . . . be better able to be adjusted , and can be adjusted from the engine bay , not from inside the vehicle.
FollowupID: 343936
Reply By: Crackles - Sunday, Nov 21, 2004 at 21:54
Another thing to check is that the fan inside the car isn't turned on as this (depending on how you plumb it) can drop the water temp before it reaches the heat exchanger giving a luke warm shower. For those that have a high capacity pump, a simple inline tap to restrict the flow will raise the temp as well.
Cheers Craig..........
AnswerID: 85297
Follow Up By: madcow - Monday, Nov 22, 2004 at 11:57
As well as closing the tap on the handpiece will slow down the rate allowing the water to be hotter. Generally If we base camp in the colder months we fill up some containers in the morning and they will heat up a bit through the day making a shower that little bit better especially for the minister of war and finance. :))
FollowupID: 343913
Reply By: Michael ( Moss Vale NSW) - Monday, Nov 22, 2004 at 14:43
Flappan, i teed my 4.2 engine off, its the best way and put a ball valve inline of the exchange hoses. The 4,2 engine is easy to tee without cutting any original hoses, i dont know where the outlet fittings are on the petrol engine.
AnswerID: 85393
Follow Up By: flappan - Monday, Nov 22, 2004 at 14:58
they are a bugger . . . I'll give you the tip . . . One is near the bellhousing.
Its doable though.
What do you mean by Ball Valve
I've seen a valve (or tap) used on watering systems. Only plastic though.
I though of using an actual heater valve. Can buy new ones for about $50. Connect a cable , and you can adjust the temp while in the shower. (i haven't proved this yet . . . just told about it).
FollowupID: 343940
Follow Up By: Michael ( Moss Vale NSW) - Monday, Nov 22, 2004 at 15:53
You can buy one from bunnings or Pirtek, it has a rotating ball inside that shuts of the flow,smooth and accurate adjustment, about $10, you would need a 1/2" BSP ball valve and 2 only brass hose tails, being 1/2" BSP thread and 5/8" tail on the other end, available from Pirtek or Enzed, the hydraulic hose guys. You could set the ball valve up for your particular water temperature and remove the arm. The remote adjust idea sounds good but i dont know how practical it would be. Most peoples problem is they just cant get the water hot enough with a reasonable flow at idle. Nothing worse than the engine ringing in your ears when you are usually out away from it all to get some peace and quiet.. Michael
FollowupID: 343954
Follow Up By: flappan - Monday, Nov 22, 2004 at 16:33
Thanks. I'll look into that.
FollowupID: 343963
