Re. Codan 6924 lunch box hf radios
Submitted: Sunday, Nov 21, 2004 at 10:04
ThreadID: 17976 Views:6791 Replies:4 FollowUps:8
Hi Guys .
How is everyone out there on this bright & beautiful morning ? Has anyone out there got a Codan 6924 preferably with V.K.S 737 chanels fitted that they wish to sell .I need a second one for emergencys in case one set dies in remote areas . Preferably located in West Aus . Thanks in anticipation .
Cheers dingdong
Reply By: Solarpower - Sunday, Nov 21, 2004 at 10:55
Perhaps a spare vehicle, spare alternator, spare batteries, spare wiring, spare generator, spare fuel and how about a spare you.
Better still, stay at home.
AnswerID: 85237
Follow Up By: dingdong - Sunday, Nov 21, 2004 at 21:24
Hi guys
thanks for your sarcastic reply solapower i do know what i am doing .I have found on trips that If i take a second radio in a convoy of 4-5 vehicles I encourage others to carry the spare set & log into VKS 737 each day they then know what to do in an emergancy . I may ad that in these convoys of friends my radio is the only one .We have had a situation where one of our crew broke a leg in three places . Not very nice .
I think it would be good if you kept your smart remarks to yourself & just stuck to answering questions asked .
Cheers dingdong
FollowupID: 343865
Follow Up By: Member Eric - Sunday, Nov 21, 2004 at 22:08
Good on ya Dingdong , Maby we should all go bush with half a tank of gas and ourselves , why carry the extra weight lol
FollowupID: 343875
Reply By: Member - Raymond - Sunday, Nov 21, 2004 at 15:19
Hi Dingdong
I would think that two codans would take up alot of room and unless you are travelling very remotely by yourself. HF radios are usually very relaible, I would look at carry a wire antenna such as bushcomm as it is more likely to damage the auto antenna than the radio. I would carry an EPRIB as a back up.
Regards Ray
Victor 2010
AnswerID: 85258
Follow Up By: dingdong - Sunday, Nov 21, 2004 at 21:35
Hi Raymond.
Thanks for your reply I only have a wire antenna we do carry all necesary stuff such as epirbs first aid kits & qualified first aiders .The reason for my post was to try & aquire another 6924 instead of borrowing one from avery generous friend .
Cheers dingdong .
VKS .746
FollowupID: 343869
Reply By: Member Eric - Sunday, Nov 21, 2004 at 22:10
Ever thought of buying or hiring a sat phone as back up . Alot smaller to carry than a HF
AnswerID: 85301
Reply By: Mike Harding - Monday, Nov 22, 2004 at 19:10
I have read your reasons for wanting another set but...
do you _really_ need one? It's your money of course but what are the chances of one set failing AND you having an emergency AND you being out of walking distance to help? It's for that remote possibility I carry an EPIRB.
If you really, really want another set consider a 27MHz CB with sideband - there is a good chance you would be able to contact someone with that.
On the matter of antennas you say you use a wire antenna - how do you get enough height (especially in desert country) to get useful range? As a radio amateur getting my half wave dipole up a decent height is _always_ a problem.
Any other radio amateurs on this forum?
Mike Harding
AnswerID: 85434
Follow Up By: Mad Dog (Victoria) - Monday, Nov 22, 2004 at 19:52
I think there's a few of us Mike
FollowupID: 343990
Follow Up By: Mad Dog (Victoria) - Monday, Nov 22, 2004 at 19:57
Mike, this short distance stuff around Aus work ok with a dipole a few feet above ground, it's only a matter of being heard not putting in a 9+
FollowupID: 343992
Follow Up By: dingdong - Wednesday, Nov 24, 2004 at 12:45
Hi Mike & Mad Dog .
The Codan 6924 was designed to work on a wire arial approx. 40 ft long I have at times run probably double that length the set has a manual tuning device fitted internally . I have used it many times just laid out on the ground has never been a time yet when it has not worked .Usually hook it up to a tree or another vehicle though to get best results . I do already own a second set but am told it has too many dry joints to make it economical to repair. Not knowing anything about radio i find this hard to believe but who am i to know .
FollowupID: 344218
Follow Up By: Mike Harding - Wednesday, Nov 24, 2004 at 19:06
Ray:
We should organise a frequency and time/day to put out a call for other forum posters. I usually take my HF set when I go bush.
dingdong:
It will be better if you can keep the antenna off the ground - the higher the better.
Dry joints? I don't know if the Codan sets suffered from significant dry joint problems (anybody?) at some time in the past but you could try applying a soldering iron to every joint you can see - will take an hour or two but it might fix your problem - I think there is also a trick with a hot air gun which is used on FM900 sets but you really need someone who has done it before. For a tech. to diagnose and fix each dry joint would take ages (and $$$$) but maybe he could run the boards through a solder bath - no guarantee though?
Mike Harding
mike_harding@fastmail.fm
FollowupID: 344289
Follow Up By: Mad Dog (Victoria) - Wednesday, Nov 24, 2004 at 21:32
I only operate mobile these days Mike. I'm not as active on the air as I once was, after 22 years operating VHF and above I ran out of modes to play with. They gave me HF privilages with the new regs but although I do have a HF rig installed in the ute I find it boring compared with the higher freqs . Still I tend to travel alone and it's a comfort in the bush whittling a few evening hours away chatting around the globe.
FollowupID: 344340
