AnswerID: 392 Submitted: Monday, Apr 30, 2001 at 00:00
Ian
replied:
Dean
I dont know if a pre-fab nylon
snorkel is available for the Feroza, but you could get a custom made one made from varying steels, ie Stainless tube, mandrel bent and polished, with a Safari airram on top.
Or else, a aluminium tube one custom bent and finished in powder coat looks really good (from a V8 40 series with twin snorkels).
Basically the process is to modify the air cleaner to connect some flexible pipe (ie plastic flex hose or fat rubber hose like radiator hose) from it to the pipe, which may be bent into the outside of the guard or a rubber bend comes through the guard to the steel pipe outside, running along the panel and up the A pillar to the Safari Air ram (available separately).
To look good, this needs to be done by a skilled person and made dressy, ie stainless is very showy.
Ian.
Reply 2 of 2
