Waeco CF 80
Submitted: Monday, Nov 22, 2004 at 18:10
ThreadID: 18013 Views:2502 Replies:2 FollowUps:0
I got my new CF 80 on Friday and took it away for the last three days.
Initially I set it up with the divders as a Fridge and Freezer to see how it went. It was holding -11 in the freezer and +4 in the fridge and it used a lot of power. My best estimate was (using a multi meter as a guide) an average of 5 amps/hour. The freezer compartment was only one third full and the fridge about 60%.
After a day and a half I removed the dividers and ran it as all fridge. This certainly reduced the power draw as it wasn't trying to keep a section at -11. I find with it set up this way it runs at -1.5 right down the freezer end and +4.5 at the far end, with varying temperatures in between. This is on light 3 with the power switch in the low mode. Now this is great, super cold beer down one end with the food that may freeze down the other kept at a more realistic "fridge" temp.
Anyone able to advise on power usage as a fridge and freezer? Will it work substantially better if the freezer is chockers?
Jim.
Reply By: Utemad - Monday, Nov 22, 2004 at 22:11
I'm guessing that it would work better with a full freezer (so long as it is all frozen). As air will warm up quicker than frozen meat or fluid etc.
Hopefully will find out this weekend though as I have pretty much decided that this fridge is the one to go for. I've been researching it all afternoon plus on and off the last couple of days.
AnswerID: 85474
Reply By: Nudenut - Tuesday, Nov 23, 2004 at 13:40
answering your last question....no!
fridges always use less power than a freezer...eg
...to cool water from say 20 - 0 takes "x" energy
now to change its state, liquid to solid (ice) takes some more energy "y"
now to lower the solids' temperature from 0 to - 15 takes "Z" ....get the idea?
much the same as driving you 4by 100, 200 or 1000 klm.....which used the most energy?
AnswerID: 85535
