snatch strap dampeners
Submitted: Tuesday, Nov 23, 2004 at 21:36
ThreadID: 18046 Views:3452 Replies:4 FollowUps:2
I have seen some snatch strap dampeners around at shows etc, has any one seen one in a working situation? and do they work? or should I stick with the towel?
Reply By: rickwagupatrol - Tuesday, Nov 23, 2004 at 21:58
beeny
i use a rope that is a bit longer than the strap,,,,attached to both vehicles,,,,taped to the strap just past the eyelets and in the middle,,,with enough slack to allow for stretch in the strap, but not enough to let the strap or shackle fly to far.
rick.
AnswerID: 85621
Follow Up By: Des Lexic - Wednesday, Nov 24, 2004 at 16:41
Rick,
I haven't heard of your suggested dampener method before but I can see some merit in it.
What allowance do you allow for stretch of the strap and I presume you would need a fairly reasonable rope diameter to give weight to the dampener.
Using a shackle is not recommended but if no other option is available, for the benifit of others reading this follow up, make sure it is a rated shackle.
FollowupID: 344272
Follow Up By: rickwagupatrol - Wednesday, Nov 24, 2004 at 23:00
hiya Des....i use a shackle coz i have one of those doodads that fit into the hitch reciever, rather than using the pin,....it has a closed hole?????? that requires a shackle to be used for snatch strap attatchment.
the rope is actually old hemp ships rope,,,,about 2 inches thick.
rick.
FollowupID: 344357
Reply By: Patrolman Pat - Wednesday, Nov 24, 2004 at 09:26
The latest recommendation seems to be to use a drag chain as a damper. I saw them doing this at the Adelaide 4WD show and had a chat with the guys afterwards (local 4wd training Co.). Obviously the snatch strap didn't let go so I can't comment as to how effective it would be as a damper. If it works great, if not there's a lot of weight in a flying drag chain.
AnswerID: 85669
Reply By: gonebush - Wednesday, Nov 24, 2004 at 10:57
My advice would be that you don't need to purchase a dampener if that's what you are referring to.
There are plenty of ways of dampening the snatch strap with equipment/gear you may already carry:
Towel (big) as you have said
Rope (as above)
Drag Chain
Tree trunk Protector/another snatch strap
Sandbag/sack with some dirt/sand in it
Ground sheet
Water crossing blind
.....and the list goes on
They will work effectively as long as the 'dampener' is properly secured/tied to the snatch strap. If you HAVE to use a shackle (to be avoided if possible) then position the dampener closer to the end with the shackle or use 2 dampeners towards either end in tough recoveries.
AnswerID: 85680
Reply By: Ralph2 - Wednesday, Nov 24, 2004 at 22:52
Hi Guy's a towel or blanket on a snatch strap is a complete wast of time if the strap breaks, it's been tested and filmed by the Toyota club in SA. The 4wd asocations Driver Training unit in S.A, state in there training manual (nationaly acredited) to use 2 at least 5Kg wieghts secured to the strap one third of the way in from each vechile. A drag chain is ideal for this, if bunched up securly and tried to the strap by rapping it over several times and tying to it's self with a half hitch. Then if the strap breaks the wieghts will help to keep the strap down and slow it up .It's unlikely if a shackel is used correctly(only used with a snatch strap when it is attached to the chassie or a solid part of the vechile, never used to join two straps)that it will become a missile. In saying that, it also must be remembered that pieces of chassie and tow bars have been pulled of some vechiles.
AnswerID: 85806
