AGM Batteries
Submitted: Tuesday, Nov 23, 2004 at 22:16
ThreadID: 18049 Views:3013 Replies:6 FollowUps:11
I've had a Lifeline 100 amp AGM for six months now.
From new it would hold 12.7 volts (100%) like a charm, and would get back to full charge with minimal driving.
After a good workout at Robe where I dropped it to 11.9v, about 40% it now takes longer to charge (still goes from 12.1, 55% to 12.6, 95% with about two hours driving). A bit of idling whacks a fair bit into it.
I'm not complaining about a battery that will charge quickly, but I'm concerned that it doesn't charge as well as it did when new.
Is this normal?
Any advice would be well received.
Jim.
Reply By: Crackles - Tuesday, Nov 23, 2004 at 23:02
Although a fair indicator, I don't believe the Voltage to be an accurate measurement of the state of charge. Point one of a volt would not be any big deal to worry about & could be explained by the temp on the day, poor connection of the test leads or even inaccuracy in the multi tester. Each & every deep discharge does some damage so over time it would be expected to lose a little performance.
Just for interest, how did you arrive at the Voltage verses % of charge?
ie: (12.1V = 55%charge)
Cheers Craig............
AnswerID: 85636
Follow Up By: Member - Jimbo (VIC) - Tuesday, Nov 23, 2004 at 23:08
Craig,
Got it from the chart on this site. Has good battery information.
http://www.windsun.com/Batteries/Battery_FAQ.htm#AGM,%20or%20Absorbed%20Glass%20Mat%20Batteries
Jim.
FollowupID: 344151
Follow Up By: Mad Dog (Victoria) - Tuesday, Nov 23, 2004 at 23:12
Voltage is only a rough indication as Crackles says. Use the hydrometer for an accurate indication and compensate for temperature as you must do for voltage readings as well...hmmm maybe no hydrometer as I think you have a sealed battery
FollowupID: 344153
Follow Up By: Mad Dog (Victoria) - Tuesday, Nov 23, 2004 at 23:16
oh yeah, battery capacity is higher with warmer temperatures.
FollowupID: 344156
Follow Up By: Member - Jimbo (VIC) - Wednesday, Nov 24, 2004 at 22:20
Ray,
It is not possible to use an hydrometer on an AGM battery. They are completely sealed.
Jim.
FollowupID: 344347
Reply By: Member - Blue (VIC) - Wednesday, Nov 24, 2004 at 00:42
Don't put doubt in my mind before I use the damn thing Jim...
AnswerID: 85647
Reply By: Member - Collyn R (WA) - Wednesday, Nov 24, 2004 at 12:57
Jimbo
Bear in mind that the charging process is an electro-chemical reaction and therefore heat-sensitive. The colder the day the longer a battery will take to charge from a constant voltage charger (which is that of a standard vehicle charging system) and the higher the voltrage across the battery at full charge.
It is likely that this is all that you are experiencing.
Trust this helps
Collyn Rivers
AnswerID: 85700
Follow Up By: DD64 - Wednesday, Nov 24, 2004 at 13:44
Collyn, from what I've read you've good knowledge in this area (I've virtually none) so could you please clarify for me:
1) are there any viable options to charge an AGM from the alternator without changing the conventional starter battery?
2) the difference between a gel cell & AGM.
Much appreciated. (Sorry for hijacking your post Jimbo.)
FollowupID: 344229
Follow Up By: David Au - Wednesday, Nov 24, 2004 at 14:04
DD64 charging auxilliary battery only
You will need to check that your battery is capable of accepting the full rate of charge from your alternator.
FollowupID: 344233
Follow Up By: Member - Roachie (SA) - Wednesday, Nov 24, 2004 at 14:39
Jimbo,
This may not suit your needs (expensive), but I just bought myself a 3 stage battery charger from Hybralec. It's a 15amp unit and cost $300- to my door (from Melbourne). I decided I needed it following the upgarde of my camper trailer fridge to a Engel 80 litre 240/12v. I added another spiral wound gel battery (Exide Orbital). These batteries are similar to your AFAIK. The guff on the internet says this type of battery charger (which has a switch to choose between "flooded" and "gel" type batteries) can be used with your battery in situ, even when there is work being done on the vehicle.
I just thought that maybe your alternator might not be fully charging your gel battery and the 3 stage unit could be plugged in overnight every now and again to "round-off" the charging process.
FollowupID: 344244
Follow Up By: David Au - Wednesday, Nov 24, 2004 at 15:53
Roachie for $300 you could buy a 40 watt solar panel and regulator and have the power free any where any place including camping.
FollowupID: 344263
Follow Up By: Mad Dog (Victoria) - Wednesday, Nov 24, 2004 at 16:13
A 40 watt 15 amp solar panel...I'd like to see that
FollowupID: 344266
Follow Up By: David Au - Wednesday, Nov 24, 2004 at 19:50
Mad Dog 6 hours maximum in the sun for a 40w panel = 15.0 amps.
Some clown company advertises an 80w panel for 70 amps a day.
Now that is guaranteed a fraudulent claim.
FollowupID: 344305
Reply By: derraux - Wednesday, Nov 24, 2004 at 16:05
If you go to this website it has lots of info on agm , jel and wet cell batteries
http://www.fridge-and-solar.net/index.html
Derraux
AnswerID: 85741
Reply By: TheUndertaker - Wednesday, Nov 24, 2004 at 20:04
Jimbo, have been researching the pros/cons of batteries for a looooong time now, and today went and bought 2x 80amp hr AGM , can fast charge like a start batt, can use as deep cycle ,zero maintenance ..... actually allways thought that 11.5v was 50% ,,,no no no no ,,, on AGM never go lower than 12v , check out Springers 12v specialists ......www.springers.com.au
AnswerID: 85773
Reply By: Member - Collyn R (WA) - Thursday, Nov 25, 2004 at 13:08
Dd64
There are no problems re charging AGM batteries from a standard alternator as such. However AGM battery makers advise against charging them in parallel with conventional starter batteries.
As a professional engineer and writer in this field I cannot advise you to go against the makers' advice, but your might care to consider the following comments and form your own view.
The main problem with charging and AGM battery and a conventional battery in parallel is that the AGM battery absorbs a high charge. There is thus a risk of the AGM battery charging heavily, but the starter battery receiving only a light and inadequate charge. If however the two are initially separated, via (for example) a Redarc relay that will only charge the AGM when the starter battery is adequately charged - then that risk is removed.
Val Rigoli at Fridge and Solar has a heap of experience re this and I suggest you give him a ring - 07 5500 5561.
AGM and gel cell batteries are vaguely related. The concept is to build a battery that has the charge acceptance and delivery characteristics of a starter battery, but with the ruggedness etc of a deep cycle battery. This essentially requires multiple but strongly constructed plates so that a large surface area is presented to the electrolyte. This enables the battery to accept (and deliver) high current levels without damage. Techically-speaking they have low internal resistance (or to be strictly correct - low internal impedance).
Conventional starter batteries are made that way, but over time 'bits fall off the plates' and eventually build up on the base of the cells until the deposits reach the bottom of the plates. At which point the battery dies. Just like that!
This is avoided (with AGM batteries) by having the water/acid electrolyte held within a glass fibre matrix that is pressed against the plate material - hence the name Absorbed Glass Mat.
Gel cell batteries have the electrolyte mixed with a material that sets to a candle-like consistency - this again serves to hold the lot together.
(The above is a very simplistic view of the technology - there are many other differences - but containing the electrolyte in some form is the main difference).
Gel cells will absorb and provide massive amounts of current - in fact they can be charged at more than 100% of their amp/hour capacity! Their only downside (apart from cost) is that they are wrecked if charged at higher than 14.4 volts. It is safer to use 14.1 and they will in fact charge very well indeed - and to 100% - from 13.8 volts.
Both AGM and gel cells charge best from a three-step charge routine, but this is less necessary than for conventional batteries.
Re the 40 watt 15-amp modules. I'm sure that David meant 15 amp/hours - not 15 amps.
Alternatively they must be for 2.4 volt batteries!
Collyn Rivers
AnswerID: 85871
Follow Up By: DD64 - Friday, Nov 26, 2004 at 12:49
Thanks Collyn, most helpful.
FollowupID: 344612
