Tappets
Submitted: Thursday, Nov 25, 2004 at 17:02
CHRIS
Any one know if the 1983 2H Diesel has hydraulic or solid lifters. Have read somewhere on the
forum that they are hard on the faces where they contact the valve. The vehicle has done 243,000 Ks and at the moment they are very quite, but would appreciate the knowledge and the adjustment tollerances should some one know. (In the 70,000 ks that I have had it they have never been adjusted).Thanks in advance.
Reply By: Member - Pesty (SA) - Thursday, Nov 25, 2004 at 17:28
Chris
Solid lifters and should be reset about every 40 thousand,
Hell that reminds me !! LOL
85900
Follow Up By: CHRIS - Friday, Nov 26, 2004 at 07:34
Pesty,
If the lifters are quite at the moment and the engine runs perfect, why do the tappets ? I would imagine that if there was a loose tappet it would be making a racket. What sort of consumption do you get around town ? My beast is consistantly consistant with 15 lts 100, but it is aftermarket Turbo and that may account for the high useage.
344563
Follow Up By: Member - Pesty (SA) - Friday, Nov 26, 2004 at 13:03
As the valves and seats wear the valves move into the head and so close up the clearence gap which makes the engine quiet for a while but overrides the valve so gases can pass through even when valve shut and so soon burns out the valve/
seat which then means a head rebuild so take your pick, head rebuild or tappets, if its not too late!!
15 litre per hundred is normal i average 15-16 without turbo.
CHeers
344617
Reply By: mcgra - Thursday, Nov 25, 2004 at 19:50
hello chris
im not sure but if you want the toyota factory manual for the engine go to
http://www.birfield.com/downloads-cat-1.html
you can down load it from there.
it is a big file but if u have adsl wont take to long or leave it down loading while u sleep should be there in the morning
graham
85919
