Toyota Landcruiser Overdrive light
Submitted: Saturday, Nov 27, 2004 at 11:48
ThreadID: 18126 Views:2192 Replies:3 FollowUps:7
Hi Guys
Would anyone be able to tell me how to change the orange overdrive light on the dash of my 100 series 1999 toyoa landcruiser. It has blown and it is a nuissance not knowing if Iam in overdrive or not. Thanking you all in advance Mark
Reply By: rig pig - Saturday, Nov 27, 2004 at 11:54
Mark,
take it to an auto sparkie, or just use a big screw driver and pry it out, at the bottom of the switch
AnswerID: 86118
Follow Up By: Niki - Saturday, Nov 27, 2004 at 16:15
in my SsangYong Musso is it easy to tell whether in over drives or not. You can feel the difference and the power .
FollowupID: 344756
Follow Up By: Kimberly Kruiser - Saturday, Nov 27, 2004 at 16:41
How many "overdrives" has a SsangYong Musso got?????
FollowupID: 344763
Follow Up By: Niki - Saturday, Nov 27, 2004 at 17:16
it is standards has one only but former model has one also.
FollowupID: 344769
Reply By: Member Eric - Saturday, Nov 27, 2004 at 14:22
its a bit of a pain , but can be done with a little patience. You need to remove the cluster to do it . Remove the top and bottom plastic surounds , be carefull there are some hidden screws that are a pain in the backside.
2 behind the ashtray , next to the vents once you undo the 4 screws that hold the cluster in you will find 5 plug in looms that go into the back of it , unclip these and cluster will come out . then you will find twist plugs on the mack of the cluster count the number of lights un from the center to know which one to change .
AnswerID: 86129
Follow Up By: Niki - Saturday, Nov 27, 2004 at 16:16
i thinks he maybe wanting to fiddle with odometer :)~
FollowupID: 344758
Follow Up By: Kimberly Kruiser - Saturday, Nov 27, 2004 at 16:38
That could be a rather defamatory supposition to be making!!
FollowupID: 344761
this would be joking's only okay ?
FollowupID: 344768
Reply By: Member - DOZER- Sunday, Nov 28, 2004 at 14:55
He can try, good luck with restting the digi readout!
AnswerID: 86219
Follow Up By: Niki - Monday, Nov 29, 2004 at 06:54
can be done ;)
FollowupID: 344976
