Refridgeration mechanic
Submitted: Sunday, Nov 28, 2004 at 22:34
Member - Blue (VIC)
Anyone on EO happen to be a refridgeration mech in or near Ferntree Gully, wanting a cashy to install a split system??? Wiring will be done, just the plumbing required...
Reply By: Nudenut - Monday, Nov 29, 2004 at 20:09
mmm no refridgerations in OZ
all refrigeration mechanics
now if i was nearby?
86453
Follow Up By: Member - Blue (VIC) - Monday, Nov 29, 2004 at 20:55
is it something the average joe can bumble through, I have a sparkie-in-law to sort the wiring, any special
tools required?
345077
Follow Up By: Nudenut - Tuesday, Nov 30, 2004 at 07:46
one has to be licenced to handle refrigerants.
air, moisture (and that doesnt mean it has to be raining) dirt etc etc in pipework will cause problems. then we have making sure the pipework is installed correctly...then etc etc etc
my advice...leave it to a frigie...or is that fridgie?
345107
Follow Up By: Member - Blue (VIC) - Tuesday, Nov 30, 2004 at 08:03
No dramas, hit a bit of a wall ringing around the local scene... thought I'd ask. Guess I'll just have to keep looking.
Blue
345110
Reply By: Member - Chrispy (NSW) - Tuesday, Nov 30, 2004 at 08:04
One thing that you probably need to see get done is proper air evacuation of the pipes between the indoor and outdoor units in my honest opinion. I installed ours bar the final electrical connection (I ran all the wiring, but had a sparky check and connect it to the circuit breaker) but was told that if I did the pipework to completion myself I'd leave air in the system - which would lead to a less efficient setup. I had the bloke who came out pump the air out and then crack the refrigerant gas stored in the outdoor unit to fill the system. Opinions between installation companies differ in this regard, as it obviously takes longer and they have to carry the gear to do it. Most just connect the pipes and crack the gas - and really don't care... they don't have to live with it.
Just a suggestion :)
Chris
86496
Reply By: motherhen - Wednesday, Dec 01, 2004 at 01:32
Are there still refrigeration tradesmen around? Like auto electricians and farmers, they're an aging and rare breed. Don't send your children to uni - the country needs tradesman to do real hands on work. With a good trade, they'll always make money (unlike aging farmers!).
Just my thoguhts for the day.
86714
