jack or terrano
Submitted: Monday, Nov 29, 2004 at 18:17
ThreadID: 18188 Views:2139 Replies:4 FollowUps:1
been test driving 2nd hand td 4x4 and now am deciding between 99 terrano ii and 99 jackaroo td. both have 100000ks both $22000 reading through the past post the injector probs in the jackaroo are scaring me as also in winter starting probs,i do like the jack better can anyone give some tips cheers bob
Reply By: theshadows - Monday, Nov 29, 2004 at 20:42
If you are after a smaller refined car I'd lean towards the Terrano ii .
But I'd say the jackaroo is a better larger car with more interior space .
shadow
AnswerID: 86461
Follow Up By: stevesub - Monday, Nov 29, 2004 at 21:15
We bought a Nissan Mistral (Terrano) in NZ last week, 1995 model, very low km and we love it. When we get back to Brisbane next year, the Freelander will be replaced by a Terrano. The Troopy however will be staying in the family - could not part with our Troopy.
The Terrano gearboxes (auto) may be weak if given a hard time towing - otherwise there are no obvious problems that we could see or have heard about.
FollowupID: 345080
Reply By: jules15 - Tuesday, Nov 30, 2004 at 11:36
We have a Terrano II - had 1992 Terrano imort before that - couldn't fault it in over three years and many long, hot trips. The TII -(we have the top of the range) is terrific - no problems - tows our camper easily, economically, and hopefully will take us right round next year - can't see why not. Presume it is diesel? if so they are as strong as an ox in our opinion. Love it.
jules
AnswerID: 86534
Reply By: Savvas - Tuesday, Nov 30, 2004 at 22:42
There's really no reason to worry about the injectors on the Jack. What you need to ascertain up front, is whether the recall on injectors has been performed on the vehicle you're interested in. The way to do this is check with Holden as it should be registered with them. If it hasn't been done, then you need to arrange it with a dealer to get it done..
Starting will be a problem if the wrong engine oil is used. Again, the information is all over this forum and if you use the right oil it won't be an issue. An excellent reference for that is right here (click).
The research you are doing right now is the best move you are making.
AnswerID: 86687
Reply By: damien - Monday, Dec 06, 2004 at 12:01
If you're interested in doing even half serious 4wding then choose the Jack.
As Savvas said, check that the recall work has been performed & ensure it has a full service history.
Starting problem is not an issue if you're using 5w40 or 10w40 oil. The problem supposedly only occured in extremely cold conditions - i've been to the snow several times & have not had a problem
AnswerID: 87442
