Another Diesel and Tacho question
Submitted: Tuesday, Nov 30, 2004 at 14:18
ThreadID: 18212 Views:1925 Replies:5 FollowUps:3
Does anyone know of where I can get an aftermarket Tacho for my 80 series diesel Std model?
What would the approx cost be.
TIA
Tony N.
Reply By: Coops (Pilbara) - Tuesday, Nov 30, 2004 at 14:22
something I've been wondering about also.
I'll be watching with a keen eye for responses
thanks Tony
AnswerID: 86577
Reply By: tour boy - Tuesday, Nov 30, 2004 at 14:37
try a wreckers for an RV or GXL complete dash. They may trade yours. The wiring should be the same a wrecker will be able to confirm this.
AnswerID: 86579
Follow Up By: Tony N. (VIC) - Tuesday, Nov 30, 2004 at 14:41
The only issue with replacing the dash is I belive the pickup sensor that goes on the motor is not installed on the Std model and from what I have read it is fitted infront of the diesel pump. So would require the pump to be removed to fit the sensor and them there is the cost of the sensor.
Tony.N
FollowupID: 345160
Reply By: Truckster (Vic) - Tuesday, Nov 30, 2004 at 15:17
Any Supercheap, Autobarn, Bursons, Repco store would have VDO style tachos.
Cost call em and ask.
AnswerID: 86582
Reply By: Member - Brian H (WA) - Tuesday, Nov 30, 2004 at 21:43
Your local coventry's also have them. Various models with different options.
AnswerID: 86663
Follow Up By: Member - Jeff M (WA) - Wednesday, Dec 01, 2004 at 14:56
How does an aftermarket Tacho work on a diesel? Is obviouslt doesn't pickup the spark the the leads...?
FollowupID: 345388
Follow Up By: Member - Chrispy (NSW) - Wednesday, Dec 01, 2004 at 14:57
I'd think it would have a sensor on the pump or maybe even a kind of "knock" sensor on the block.
Anyone?
FollowupID: 345389
Reply By: Member - Brian H (WA) - Thursday, Dec 02, 2004 at 00:02
Basicaly they are driven by pulses picked up from various points around the place. Most common is off the harmonic balancer (big pulley on the front of the motor at the bottom). These can be either from reflective tape or magnetic depending on manufacturer. There are some that are cable driven like the speedo.
That's it in a nut shell
AnswerID: 86893
