Noise in front end/steering
Submitted: Tuesday, Nov 30, 2004 at 16:41
ThreadID: 18216 Views:2284 Replies:3 FollowUps:0
Hi all, I am hoping that someone might shed light on my problem.
I own a 3.0 TD Nissan Patrol (2000 model) and recently I have begun to hear a squeaking/springing type of noise from the steering/front end when I turn the wheel. Not sure if this caused by dry/worn bushes or something else but would be interested in anyone has experienced such a problem and can shed some light on what it might be. It doesn't make any noise when driving in a straight line, but increases in volume depending on the severity of the turn.
Reply By: Member Eric - Tuesday, Nov 30, 2004 at 16:45
try a little grease on the steering stops , usually does the trick
AnswerID: 86592
Reply By: Member - Graham P (QLD) - Tuesday, Nov 30, 2004 at 16:47
Check the oil level in your power steering.
Graham P
AnswerID: 86594
Reply By: dublediff - Tuesday, Nov 30, 2004 at 22:40
Try rotating the front springs in their seats a little. My 4500 had terrible noises, particularly when cold. Apparently the springs move in the seats and take a bit of settling in. Jack the car up on the chassis, taking weight off of the front end completely and you should be able to turn the springs relatively easy.
AnswerID: 86686
