3 posts in 1..Gq turbo's are wickedddddddd..
Submitted: Tuesday, Nov 30, 2004 at 22:30
ThreadID: 18232 Views:2981 Replies:5 FollowUps:3
"1st post from a few weeks ago"
As bizzare as this sounds here is the story.............
I used to run 33x12.5 A/T's for a year and the car had heaps of power (well as much as you can have without a turbo),,, so i was pretty happy.... Changed oil filters with the oil every 5000kms, fuel and air filters every 10,000kms............
The other week i bought a set of Cooper S/T's in the exact same size and then the next thing i find out is that i have appeared to have lost about ½ my horsepower,,, maybe not ½ but at least quarter.....
It used to pull like a schoolboy with his first womens weekly magazine but since the tyre fitment the power has vanished... Can a more agressive tread pattern cause this???????
There is little black smoke,, all-tho i think the fuel econ has gotten worse... 15litres per 100 now,,, used to be as good as 13....
Have changed the oil and air filters recently and no change.....
Can injectors pack in as quick as this???????? or a coincidence fuel pump problem??????
Any good places in Adelaide to go and see without the usual $1000 entrance fee????
Regards Grant......
"2nd post from a few weeks ago"
This post coincides with yesterdays post "CRAPPY GQ 4.2 diesel".....
Well it's been a good day and most tests have been completed.......
I drive a particular hill on the way home each night after work and it is good comparison....
I think i have said before that with my 33"x12.5"x15" A/T's i used to make it up to about 90kmh by the base in 4th and by the top i used to be able to keep it around 80ish kmh which i thought was great....
So i recently buy some Cooper ST's 33x12.5x15 and all of a sudden my base speed is 80kmh and my top of the hill speed is 60ish..... So no wonder i start to worry about things like injectors, fuel blockage etc etc etc....
Tonight i put on my original wheels and tyres which i keep at work 31x10.5x15 A/T's and my base speed is 100kmh and i held that speed till ½ way up but didnt drop below 90kmh, even at the top...
All of my speed loggings are done by GPS and not the speedo.....
So not only what a huge difference tyre size makes but the different types of treads also as both of my 33inch types of tyres are the same OD.....
40psi used at all times...... I will leave on my 31's for a couple of tanks of fuel to see what fuel econ is.......
Thanks to all that answered my last post...
"3rd post which is from now"
So i left the 31inch tyres on for a couple of weeks and travelled around getting 13litres per 100ks and got my dearly missed power back but the vehicle looked so stupid with little tyres on it with the high lift and the speedo was out by quite a bit because it was recalibrated for 33inch tyres, so when i was travelling at 90kmh the speedo was almost showing 105kmh....
I put back on the Cooper S/T's 33's x 12.5 x 15 and the power disappeared and the fuel economy went all the way to 16litres per 100k's.....
I booked the Patrol in for a 'DTS' turbo and it was fitted yesterday and today and differences are mind blowing... I should have done this a year ago.....
Before the turbo i had a measured 48kw and after the turbo a measured 77kw...
When i went to my 'test hill' tonight it was a totally different ball game.....
In 4th gear which is what i used in my last quotes,,,,, 90kmh at the base of the hill with the Coopers on and held 90kmh all the way to 3/4 up the hill and then i put my foot down and it picked up to 100kmh...
I could have got to 100 by the bottom of the hill but traffic was bad...
I have just a fuel econ run to do and then i will have to find another bee for my bonnet...
Reply By: Member - Robb (NSW) - Tuesday, Nov 30, 2004 at 22:38
Those Cooper ST's have really turned into some expensive tyres... ;)
AnswerID: 86683
Follow Up By: Voxson (Adelaide) - Tuesday, Nov 30, 2004 at 22:46
They made me see the light...
FollowupID: 345250
Reply By: cokeaddict - Tuesday, Nov 30, 2004 at 23:19
Dont you just love it :-)
AnswerID: 86696
Reply By: Truckster (Vic) - Wednesday, Dec 01, 2004 at 09:19
77kw after the snail installed.. Makes you wonder how these dudes get 120+....
What boost you running?
Get yourself an EGT ASAP too.. see what exhaust temps your getting for that power.. Drive off the EGT, and save your donk!
AnswerID: 86750
Follow Up By: Member - Chris M (QLD) - Wednesday, Dec 01, 2004 at 10:07
Next time your up trucky, I'll show you! ;-)
FollowupID: 345308
Follow Up By: Voxson (Adelaide) - Wednesday, Dec 01, 2004 at 13:45
12.05psi boost @ 3004rpm
11.4% Opacity
32.7 Air Fuel Ratio
They said that most diesel 4.2's with 31inch tyres only make up to 55kw without a turbo..
They also said that 33inch tyres can easily rob about 7-10kw...
I could have made mid 80's with 31's...
FollowupID: 345372
Reply By: duncs - Wednesday, Dec 01, 2004 at 11:10
The thrust of these poosts coincides with what I found years ago.
I had a GQ TD42 which had a turbo when I bought it. I put a set of Cooper muddies on it, don't remember exactly which model. When I replaced those tyres witha set of AT's I got 80km more from a tank of fuel. That continued until I sold the car.
An extra 80km from every tank of fuel more than paid for the tyres in the 80,000km they were on the vehicle.
As was said earlier makes the Coopers pretty expensive.
Duncs
AnswerID: 86774
Reply By: Member - Bradley- Wednesday, Dec 01, 2004 at 14:16
Hmm i know your pain , went from 245/70 693's to 265/75 MTR's and lost a fair bit of poke in the jack, from 12-13 to 14-15 per 100, still spins the mtrs though when it has to. big difference in the construction weight of the 2, got me thinking about the supercharger for the v6 !!! I shouldn't be greedy, it still bops along pretty well (and the missus doesn't really know how much i have spent recently on it :-0 Might have to buy her the 'ring' to convince her of my need for more power!!)
All these recent 'good news' stories of the turboed diesels might just turn me to the dark side....
AnswerID: 86815
