1999 jeep cherokee turbo diesel
Submitted: Wednesday, Dec 01, 2004 at 09:19
alley
Hi everyone,
Im in search of a mechanic that can assist me with a huge problem with my turbo diesel cherokee. I have exhausted all my avenues. You guys are my only chance. Im 2 x waterpumps down and 2 x head gaskets also. My mechanic is at a loss to find the problem. Hoping there is mechanical genius who can give us some thoughts. No the motor has not overheated.....HELP Alley
Reply By: theshadows - Wednesday, Dec 01, 2004 at 12:01
they are just a motor nothing special...whats the problem.
shadow
86783
Follow Up By: alley - Wednesday, Dec 01, 2004 at 21:15
Thanks for you response. Its seems that there is problems woth this motor. Apparently its a fixed motor that Jeep have put into a vehicle thus the vibrations etc cause everything to vibrate loose.....Ill keep you posted....Ive already had to have the turbo fixed as had several floating pieces inside that had come undone.....thanks again Alley
345462
Reply By: Member - gimme (QLD) - Wednesday, Dec 01, 2004 at 12:13
is it a VM diesel?
86786
Follow Up By: alley - Wednesday, Dec 01, 2004 at 21:16
Yes Apparently........thanks anyhow will keep you posted alley
345463
Reply By: Member - gimme (QLD) - Wednesday, Dec 01, 2004 at 12:17
Alley,
Is that the model that had the VM diesel in it?
86788
Follow Up By: alley - Wednesday, Dec 01, 2004 at 21:19
Yes that right....Have you any ideas..... It appears from what I have come up with in the last 24hrs that this vehicles nuts bolts and everything else dont stay tight......Alley
345465
Reply By: Member - Chrispy (NSW) - Wednesday, Dec 01, 2004 at 12:22
Alley - uhmm.. where are you located?
86790
Follow Up By: alley - Wednesday, Dec 01, 2004 at 21:20
Sunshine Coast queensland........
Any ideas....thanks Alley
345467
Follow Up By: Member - Chrispy (NSW) - Wednesday, Dec 01, 2004 at 22:37
I'd be taking it to Hammond 4WD Centre - the Jeep specialists in QLD
Address:
Corner Redland Bay & Neumann Road, Capalaba 4157
Queensland, AUSTRALIA
Phone:
61 7 3823 4966
61 7 3399 3348
61 7 3899 2199
Fax:
61 7 3823 4977
Email: ham4wd@powerup.com.au
http://www.hammond4wd.com.au/
345488
Follow Up By: alley - Wednesday, Dec 01, 2004 at 22:52
Thanks Chrispy......
Ive taken the details.....
as soon as I can..... Thanks heaps....Alley
345495
Follow Up By: Member - Chrispy (NSW) - Wednesday, Dec 01, 2004 at 23:03
Yeah... no worries Alley :)
I guess the problem with the 2.5 turbodiesel in the XJ is that it was always considered a short-run hybrid (almost experiment), and never really got the development it should have. Typical Yanks were never into diesels as a rule, so this model was primarily whacked together for the European and Aussie markets. They've come a long way now though........ the 2.7 in
mine is a pearler.
I have mates who have your model, and have flogged them mercilessly for years without complaint. Sounds like you got one that someone has had a go at....
I'd be more than interested to see what transpires over this Alley - so keep us posted!!
Also - go to
http://www.ausjeepoffroad.com - and ask the questions you need to in the Cherokee
forum - you're sure to find a pile of people that know what to tell you.
Chrispy
345499
Follow Up By: alley - Monday, Dec 13, 2004 at 21:30
Hi evryone.....
Just a follow up as promised....
I finally have my Jeep back and it is running great...
It appears that all the welch plugs were corroded. There must have been a fine leak which explains the
water vertually disappearing...
They have alll been replaced....
May be I have been using the wrong coolant????
Maybe you guys can help me out with this????
And although this has been a nightmare of a year with this 4wd I really do like the vehicle and would like to keep it....
So fingers crossed!!!!!!!!!!
Alley
347437
Follow Up By: Member - Chrispy (NSW) - Monday, Dec 13, 2004 at 21:34
Great to hear Alley :)
Where did you end up taking it? Hopefully it will now give you years of service.
Chris
347438
Reply By: Terry - Wednesday, Dec 01, 2004 at 13:19
Try Detroit Diesel.... pretty sure VM is a divsion of them
86805
Follow Up By: alley - Wednesday, Dec 01, 2004 at 21:24
It looks like it...My mechanic tells me he found a leaking welch-plug as
well........
What a headache this has been......Alley
345469
Reply By: Dave - Wednesday, Dec 01, 2004 at 18:19
Hi alley,
have you tryed a Chrysler Jeep dealer?
The VM Diesel as far as I know is an Italian diesel.
Definately go to a Jeep dealer with this problem as I am sure they would be familar any problems with this model.
cheers,
Dave.
86846
Follow Up By: In hock - Wednesday, Dec 01, 2004 at 20:04
fix it and trade it .
345434
Follow Up By: Terry - Wednesday, Dec 01, 2004 at 20:08
VM engines are made in Italy.The place makes engines which are sold both as Detroit Diesel and VM as both VM Motori and Detroit Diesel are owned by Daimler-Chrysler.
A Chrysler mechanic told the old man it would be cheaper to go to Detroit Diesel for engine parts for his TD Jeep.
345437
Reply By: Member - gimme (QLD) - Thursday, Dec 02, 2004 at 07:36
hello Allley,
Range Rover were using these diesels in the late eighties, not for long though.
Give Dave a bell at British Offroad at Forest Glenn, he will be able to tell you who to go to on the Sunshine Coast, best of luck. gimme
86907
Follow Up By: Member - gimme (QLD) - Thursday, Dec 02, 2004 at 07:41
ALLEY,
I had one of these in a Range Rover, the trick with them was the sequence , not the torque of tightening the heads, all four of them.
send me an email at :
mikm52 at hotmail.com
and I will give you a range rover
forum to go to and ask the question again, someone there will be able to help you.
regards,
gimme
345517
