Damage to rear mounted spares
Submitted: Friday, Dec 03, 2004 at 09:46
ThreadID: 18293 Views:4580 Replies:17 FollowUps:40
Was in Bunnings carpark the other day when I heard this almighty bang. Looked up to see that a parked Falcon ute had rolled into the spare tyre of a Rav 4, damaging the rear door. I reported it to Bunnings & they put it over the PA. When I left the store I noticed that the Falcon was parked back where it had started, but no note to the RAV owner ref the damage. Was just about to leave a note when the owner walked out, and yes, he was not aware of the damage. On my way home looked in the mirror, guess what, I had a Falcon ute behind me. He followed me for miles untill I pulled up at the Cop Shop. End of this story. The moral of the story is how many people have had damage done either by backing into, or having someone run into them with rear mounted spares. I have a 60 Series and don't have this problem, but have often wondered what damage one would cause with your bullbar should you happen to nudge a vehicle while parking. I can see the benefit of rear mounted spares, but how often do you get a flat bogged to the hilt in the mud or sand. As a ex army Recovery Mech with on hand experience, to me it's as bad as the old Land Rovers with the spare on the bonnet and is just another way to save space.( Before someone says just look at the amount of Landcruiser 100 Series spares in the Simpson, take a look under the back of a 60 series, you have to bust your neck to see it). So why are the spares on the back. Believe me I am not biased, but common sense should be applied at times.
Reply By: Shaker - Friday, Dec 03, 2004 at 09:51
Maybe it allows for greater clearance under the vehicle, or allows for larger capacity fuel tanks, or some may say just looks good too!
AnswerID: 87103
Reply By: GO_OFFROAD - Friday, Dec 03, 2004 at 09:58
Ask your wife to change the flat tyre on the car and see how she goes lifting it on the back door or carrier, compared to winching it up off the ground under the car.
My 80 I ran a 16" steel rim with a 7.50 spare, and lifted the brackets another 12mm, removed the bar at the front of the spare, and you then couldnt see the spare from behind.
Another product we have just developed will make rear door spare access on and off alot easier, as well as serving another purpose, and should be out Jan 05.
AnswerID: 87104
Follow Up By: Shaker - Friday, Dec 03, 2004 at 10:52
Ask her grovel in the mud under the vehicle to drag it out & i bet you get put in your place.
Plus,I would like to see the result of a survey to see how many people would ask their wife to change a 4x4 wheel!
FollowupID: 345793
Follow Up By: GO_OFFROAD - Friday, Dec 03, 2004 at 11:05
Shaker, you need to look a little further afield than your own yard, to see people who live, work or travel in country areas have the wife driving the car alot, and its not a matter of asking, but neccisity to change a flat when you get one.......
Now if you use the winch under the car, you will find you dont need to get under the car, as its all done from the rear of the car, even the spare willd rag out far enough to disconnect and reconnect from the winch position.
And Ive wheeled with some blokes who cant get the spare on the back, let alone ladies.
FollowupID: 345795
Follow Up By: MrBitchi - Friday, Dec 03, 2004 at 11:09
Ask the wife to change ANY flat :-( RACQ is only a phone call away. Personally I prefer the back door arrangment, specially after seeing a cruiser rip one to pieces on a rock at Manar Park.
FollowupID: 345796
Follow Up By: Davoe - Friday, Dec 03, 2004 at 16:58
Not quite right GO alot of mine vehicles are utes and carry the spares in the tray or in those fancy holders behind the cab that allow them to be wheeled out. other mines dont carry spares at all an call up for a spare. the utes with underslung spares soon become termanilly caked with mud and inoperable. Currently where I am working for an exploration mob they have a great set up it goes under the tray and above the fuel tank. you open it up from beneath the tailgate and there are 2 handles you pull to get the 2 spares out. The coments about women and spares are unfortunatly spot on I am yet to see a female change a tyre completely by herself 1 place I worked at they would drive the vehicle to the 6 level workshop with a flat stuffing a tyre because they refused to change them
FollowupID: 345892
Follow Up By: Shaker - Friday, Dec 03, 2004 at 17:01
I was just wondering, how do you winch it down if it is only a few inches off the ground? Like in sand, mud, ruts etc etc.
Also it is amazing how many of "manufacturer that sells 3 times as many vehicles" vehicles have after market rear wheel carriers fitted.
FollowupID: 345893
Follow Up By: GO_OFFROAD - Friday, Dec 03, 2004 at 17:03
So what your saying is, for one of the 3, I mentioned, where you are the spare under isnt perfect, but its still an OH&S issue, and even roll down holders are fitted to trays to make chnaging tyres a better situation?
As well as women refusing to change/lift them.
FollowupID: 345894
Follow Up By: Davoe - Friday, Dec 03, 2004 at 17:30
Not having a go GO just informing you of situations and solutions etc that companys try. The last place I worked one of the girls had some type of pully system to lift tyres but it looked unused and its method of operation was unclear. I have seen chicks get tyres down off roofracks bythemselfs. The problem is if there is only one of them. Wich is why I was employed to choeffer them around - the guys would go by them selfs, 000k of taxpayers money to employ 2 guys whose main job it was to change tyres. I dont mind the windup system everyone says "what if you are stuck in mud/sand and you have a flat??? well get it unbogged then fix the flat a flat tyre will get you out of a bog quicker than a fully inflated one + how likely is that scenario you could even pump it back up. it should retain its air long enough for the recovery unless it is stuffed/off the rim. My l/c camper has the best of both worlds it has a rear mounted spare that doesnt swing to the side but down to below knee high
FollowupID: 345900
Follow Up By: GO_OFFROAD - Friday, Dec 03, 2004 at 17:40
Couldnt agree more Davoe,
and just seeing where some people choose to change flats on the road side, when moving 10-20m more isnt going to hurt the tyre, to be 100% safer astounds me, let alone in a 4wd situation, where just jacking the car could be an issue or a health threat, for the sake of a small drive to a safer position.
One of the good things of having secondairs in my tyres, they dont come off the rim and you can drive 1km+ on a flat tyre slowly, and chnage it somewhere better etc and not have to clean the tyre out afterward.
FollowupID: 345902
Follow Up By: Bonz (Vic) - Saturday, Dec 04, 2004 at 18:10
What sort of gizmo is it GO? I can envisage a type of mount that concertinas on a gas strut, but what've you come up with?
FollowupID: 346021
Follow Up By: GO_OFFROAD - Saturday, Dec 04, 2004 at 19:36
Its another of our "thinking outside the square" productions which allows the spare to be lifted up by ratchet rope, gives you somehwere to put the chainsaw/arm full of wood/garbage bag, and can incorparate a ladder for getting on the roof rack as well.
Some of our other stuff is here currently,
some pics on the web for now
FollowupID: 346026
Reply By: Johnno1 - Friday, Dec 03, 2004 at 10:11
that is a good effort for the ute to be high enough to hit that spare.
Did the guy stalk you ?
AnswerID: 87107
Reply By: fozzy - Friday, Dec 03, 2004 at 10:25
CHRIS not nice having that happen to you at all and great that you told other car about being hit but in relation to spare on back-my 80 series had wheel carrier on back initially spare underneath scraped quite consitantly and i had long range tank fitted and the spare sat on roofrack until i could afford rear wheel carrier-u ever tried lifting spare up and down from roofrack
have 100 now and one of first things i did was take wheel out from underneath and put on wheel carrier
fricken pain in a... having to open the swing away carrier every time u want a beer or something out of back but certainly no tyre underneath makes for easier swapping of rims
never had to get tyre from underneath in mud and will never have to and will never want to
rear wheel on back is part of car and never had problem with hitting cars in carparks or had wheel hit yey but maybe im lucky touchwood
if i never went off rd or changed wheels or had long range tank fitted then i would definitely leave wheel under back of cruisers
AnswerID: 87111
Reply By: Davoe - Friday, Dec 03, 2004 at 11:04
When I was a kid I tried a runner after reversing into a car and the upshot was I was fined for reversing without due care and charged with leaving the scene. As I found out it is not only rude but an offence and costly
AnswerID: 87121
Reply By: ianmc - Friday, Dec 03, 2004 at 15:29
An underslung spare fat wheel is not an option in any real off road situation & I wonder how Tojo have got away with it for so many years. Just have to look at the minimum clearnce between tyre & road in a loaded 4by to see that.
Heard of one being ripped off up the Cape & it got loose & destroyed the
camper trailer suspension., then later on the owner cooked his motor too as he wasnt watching th temp guage at the right moment I guess. What a feeling!
How the heck can you get one out from under when in thick sand or mud with a flat
& a big load onboard??
AnswerID: 87162
Reply By: Member - Jeff M (WA) - Friday, Dec 03, 2004 at 15:34
Chris why does having the spare tyre on the back make your vehicle more prone to being hit in car parks?
All 3 of my 4bies have had their spares on the back and have never experienced a problem. Mind you I always have my reece hitch locked on the back of the car so good luck getting past that bit first! LOL.
Personally I would have pulled over and got out of the car with my trusty wheel brace in my hand, if he pulled up I would have pollitally asked him if there was a problem as I tapped it into the palm of my other hand. What a moron, people like that make me SO ANGRY!
AnswerID: 87163
Follow Up By: CHRIS - Friday, Dec 03, 2004 at 16:18
Jeff M( WA),
No I didn't say it was more prone to getting hit in carparks. The point was that most spares are not protected from anyone running into them period. Most steps or towbars on the rear of these vehicles do not protect the spare as they do not protrude out far enough should you back into a wall etc. I do a lot of pig shooting and the few times that I have backed into trees or stumps at night would not do a rear mounted tyre & door much good. I have had numerous flats in the field at night and just lifting the spare off the ground onto the axle is enough for me. Example: My 60 Series has a very solid rear step that would hold a bull out to P---ss, it has taken a hard enough hit at times to darn near snap my neck without any damage, if the same was to happen to the other, well you guess.
FollowupID: 345883
Follow Up By: Member - Jeff M (WA) - Friday, Dec 03, 2004 at 17:08
Ok, I can see where your comming from, however I try not to hit things, but then I'm not a bush basher and if I had a 60 I'd probally not worry so much.
I guess because the tyre is so high off the bumper if you were to hit anything 9 times out of 10 it would'nt be that high up, I guess if you were to back into a tree trunk you might be in trouble, however they are quite often thicker at the base anyway and you would be more likley to stop the car on the tow bar than the rear tyre.
I've got alloy rims and am 6'3" so don't have a problem lifting the tyre up onto the back.
But each to their own! :-P
PS - Pig shooting would be heaps of fun I recokon!
FollowupID: 345895
Reply By: theshadows - Friday, Dec 03, 2004 at 16:43
by the time you muck around getting the spare out from under the car then find out its flat{ because being under the car you cannot be bothered to check it.} then change the silly tyre.
its just as bad dropping the tyre off the back of the wheel carrier {but at least I'm more likey to check it to see if it needs air.}
All I do now is pop the compressor on and fix the leak while the wheel is still on the car. {and I dont need to fiind a jack} with a external repair pack. {if I got my mallet and tyre levers with me} I'll pop the tyre off and put an intenial plug in the tyre if Im not in a hurry.
shadow
AnswerID: 87174
Reply By: Member - Roachie (SA) - Friday, Dec 03, 2004 at 16:44
Now let's see for a minute........
I can buy a swing away rear wheel carrier to stick on the back of a cruiser etc which suggests people like the idea and are prepared to put up with having to lift the wheel up to avail of the benefits of better departure angle and fitment of a larger fuel tank.
However, I just rang around (only in my imagination; I'm not really THAT silly) to all the aftermarket places to see if I could get a replacement set-up so I could move my Patrol's spare to UNDER the body......guess what; nobody sells anything like this. Now, I wonder if the reason no-one sells these is because NOBODY WANTS SUCH A STUPID SET-UP.
Sorry Chris, but I really don't think you've thought this through very well before posting the question.....
I agree that a petite woman would have strife lifting a 265/75 up onto the wheel carrier on back door etc. This, to me, is another reason why people should think twice before buying this sort of vehicle as a shopping trolley. I bought my Patrol cos I like getting into the bush. If I was a city dweller who loved going to flower shows and playing marjon (spelling???) or chess, I'd buy myself a nice little Comode or Hyundai or Subaru Liberty. Much safer for the kids and easier to park etc. In my mind it's a case of horses for courses. You wanna own a big, tough 4x4, you gotta have the muscle to go with it.
Having said that, I have seen a set-up an oldish bloke had on the back of his twin rear wheel carrier that incorporated a small jib and wind up winch (like off the front of a motor boat trailer). It was positioned so that he could winch either of his spare wheels up to the right height and swing it around to get onto it's mounting point.
Just my opinion....not looking for an argument...
AnswerID: 87175
Follow Up By: Andrew - Saturday, Dec 04, 2004 at 14:46
Chris
You would be a member of a VERY small minority of 4WDers that think having a spare underneath is better than on the back. No one is doubting your military experience, I just cant see its relevance to this discussion.
A spare mounted on the rear is much less likely to be damaged offroad than one that is slung underneath. Thats MY opinion.
FollowupID: 346007
Reply By: Member - Steve (ACT) - Friday, Dec 03, 2004 at 21:44
A little off the topic, but I've had two visits to shopping centres in the last two months where a vehicle has clipped the 4wd when either reversing out in coming in to park, only marked the silver panel at the bottom.
But to my surprise, no utter shock one time the culprit left name, contact number and regos details, with a sorry. We decided that it wasn't worth chasing but rang them to thank them for their honesty. I think they were equally shocked that we were happy to let it go.
Raises the old faith in humanity thing, until we came home and discovered we'd been clipped again last week, no note this time!!!
Sandy
AnswerID: 87214
Reply By: ev700 - Saturday, Dec 04, 2004 at 02:00
Most of the damage caused to our vehicles has come from shopping trolleys.
We should lobby for mobile security patrols - this would help to cut the thteat of theft and assault too.
Shopping centres should take more care in the design of car parking, especially access.
AnswerID: 87236
Reply By: Coops (Pilbara) - Saturday, Dec 04, 2004 at 08:55
Now who's wife changes the tyre anyway - a small minority I'm betting.
My mobile would be running red hot as soon as she saw it was flat (if she saw it).
I do agree with the lifting bit as I struggle sometimes but have only had to do it twice other than for rotation so am happy with that.
Rear wheel carrier allows me greater clearance as well as cleared up space for LR fuel tank. Also can't fit 2 spares underneath!
Shopping Centre bings - I sorted that with a lift kit and bodylift combined with extra wide sidesteps. Now if their kids open the doors too quickly the damage is to their doors and not mine. Haven't had a bing since although I don't frequent city malls much either
AnswerID: 87251
Reply By: Bob of KAOS - Saturday, Dec 04, 2004 at 11:28
Changing wheels on the 'rubber bladed grader' is an absolute PITA. Give me rear door mounted spares every time. When I take the trailer I remove the underslung spare and carry it on the trailer.
AnswerID: 87256
Reply By: GO_OFFROAD - Saturday, Dec 04, 2004 at 19:48
And the most interesting part of this whole conversation for me, who has had the spare on the back of the last 2 cars, [prado and troopy] in the back of another, [40 with swampers] and mounted in the back of the 80 for comps, [where back seat should be] and under the back for 4wding, is that in the last 5 years, because I run the right tyres, at the right pressures, I have used my spare twice..........
So to be trying to buy a car because of where the spare is seems a little weird, do you check the position of the jack?...........the tool kit?
I know I would much prefer the spare under the back like my 80, that having to open and close it to access the back all the time, and obviously the spare under isnt a problem, or I guess Toyota would sell 5 times more, rather than just 3 times more than anyone else......
AnswerID: 87282
Follow Up By: Andrew - Saturday, Dec 04, 2004 at 22:27
3 to 1 is the ratio of private sales for Patrol and 100 series isnt it?
That would say that the recreational market (which is what this forum is about) prefers the tyre on the rear. And on Prado, Pajero,etc. In fact isnt the 100 series the only wagon with the spare underneath?
FollowupID: 346060
Follow Up By: GO_OFFROAD - Saturday, Dec 04, 2004 at 22:59
No, its not the ratio of private sales of each, so that sort of makes the rest of your post NQR as well I think.
FollowupID: 346063
Follow Up By: Andrew - Sunday, Dec 05, 2004 at 00:08
Yeah I know, its really about 2 to 1 in favour of the Patrol. I used your 3 to 1 ratio because you also pulled it out of the air so I thought that was fun.
You disagree that a large % of the rec market is rear mounted spare????
FollowupID: 346069
Follow Up By: Mad Dog (Victoria) - Sunday, Dec 05, 2004 at 08:08
Hmmm, I wonder how many base their purchase on where the spare is mounted, most wouldn't think about it. Mine used to be under but now sits on a Kaymar carrier and there's a bracket inside the tub for another.
LPG tank underneath.
FollowupID: 346091
Follow Up By: GO_OFFROAD - Sunday, Dec 05, 2004 at 08:32
Andrew,
if you look at the sales figures toyota hold a 21.7% [aprox] market share, while nissan has a 6% share of the market.
The 100 and patrol sell close to equal, with the prado selling nearly 2-1 over them.
As for the rear door spare, I simply highlighted why they come with a winch and go under, as some didnt seem to know why.
FollowupID: 346095
Reply By: ol55 - Saturday, Dec 04, 2004 at 22:05
Hi all.
Just read through all the responses and the main debate seems to have developed into - should the spare be below or on the back door?
There are good reasons given above for both cases. I have had a Jackaroo and a Maverick (on door) and an 80 series (below). My personal preference is for 'below'.
An aspect I didn't notice anyone mention with the Rear door thing - is the lack of visibility. I also found it a pain the r's with the limited access to the rear and the fact that many , many times you could not swing the rear doors open enough due to obstacles - or even in the garage at home without opening the garage door.Sorry for getting off thread with that aspect but it is very much related to the location of the spare. I love the horizontal split of the 80 or 100 series tailgates compared to full or 3/4 swing out doors.
Incidentally, I now drive an 03 Grand Cherro CRD which has the spare in a well under the floor but inside. That has it plusses and minusses too. PITA if you get a flat when the rear is loaded...but at least your spare is not a back breaking job to get out ...and it's nice and clean LOL. However, Grand has a lift up rear window which is great for getting smaller things (like stubbies) out with out having to open the back door. There is no vision issue of spare blocking 3/4 rear window view. I can fully open the rear (same as 80/100series) in the garage with garage door shut - or open in many limited spaces that you cant open the swing out doors.
Unfortunately I have had flats in all those vehicles - mainly nails/screws picked up on building sites and the like. I'm not built like a brick sh*thouse and apologise for having owned so many 4bies in ignorance of that pre-requisite.
As for spare wheels - I found the 80 series almost as easy to access as the Grand (which was not loaded at the time luckily). I buy my 4bies mainly for towing and for the extra load carrying versatiliy inside.
These are just my observations and experiences and I dont pretend to inflict them on any body - just simply offering another viewpoint to keep a balanced debate. Cheers all.
AnswerID: 87297
Follow Up By: silverprado120 - Saturday, Dec 04, 2004 at 22:51
Hi ol55
Now I have a drawer system etc. where should I place the spare tyre?
keep it clean, Lol
Cheers Klaus
FollowupID: 346062
Reply By: Andrew - Saturday, Dec 04, 2004 at 22:43
ummm........... LMAO
Lexus LX740, Toyota LandCruiser 100-105, Toyota Hilux 4 Wheel Drive
Date: 13/06/2002
Supplier: Toyota Motor Corporation Australia Limited
Category: Motor Vehicles
Product Info: Campaign Number: 2506F. Lexus LX470, Toyota Land Cruiser 100, 105 models produced from 7 January 1998 to 2 September 2001 , and HiLux 4WD models produced from 29 July 1997 to 2 December 2001.
Defect details: When the above models are regularly driven on rough corrugated roads at high speeds for long distances, the spare wheel winch wire cable may become frayed due to road transmitted vibration acting on the under body mounted spare wheel.
Consumer action: All owners of affected vehicles will be contacted by letter. Owners are requested to return their vehicles to an authorised Toyota dealer for rectification.
Make: Toyota
Model: Lexus LX470, Toyota Land Cruiser 100.105 and Toyota Hilux 4WD
Model Years From: 1997-2001
Consequences: The wire cable strength decreases and the spare wheel could detach from the vehicle as a consequence of the cable breaking
Market Coverage: National
Recall Coverage: National
AnswerID: 87302
Follow Up By: GO_OFFROAD - Saturday, Dec 04, 2004 at 23:01
That was when they went to cable from chain.
FollowupID: 346064
Follow Up By: Andrew - Sunday, Dec 05, 2004 at 00:13
Really. After all of that R&D and engineering money?
If the mining and utilities sectors prefer underslung spares, as has been quoted, and they are so hard on their vehicles, why did it take five years for Toyota to find this out????
Maybe the alleged halo above Toyota is another myth????
FollowupID: 346070
Follow Up By: Andrew - Sunday, Dec 05, 2004 at 00:30
"went to cable from chain" ?
I read it that the cable is the problem. Maybe they changed to chain during the recall. What did the 80 have before 1997?
FollowupID: 346072
Follow Up By: GO_OFFROAD - Sunday, Dec 05, 2004 at 08:33
Wow, this must have you thinking, 2 replies LOL
Chain.
FollowupID: 346096
Reply By: ol55 - Saturday, Dec 04, 2004 at 23:14
Hi Klaus,
I'm sure you will have your spare someplace that suits YOU. Just as I have mine someplace that suits ME.
As for the Toyota recall notices, firtsly looks like I was lucky with my 1997 80 Series, second - I'm surprised they had to recall all those vehicles - it would appear that the so called Toyota reliability is indeed a myth. I know I had two speedos replaced in mine and now they have issues with the A- arms too.....hmmmm....
Looks like we all are at the mercy of the gods no matter which brand we buy.
AnswerID: 87304
Follow Up By: Mad Dog (Victoria) - Sunday, Dec 05, 2004 at 08:28
I work in the vehicle manufacturing industry and have access to lots of figures on the computer at work. A motor vehicle is the most complicated mass produced item made on this planet and no manufacturer is immune from problems but toyota does indeed do better than most in the THG (things gone wrong) stats.
FollowupID: 346094
