Hiring Solar Gear
Submitted: Friday, Dec 03, 2004 at 16:09
ThreadID: 18302 Views:2314 Replies:6 FollowUps:1
we're planning doing an 8 week trip mid next year and rather than install a dual-battery setup I thought hiring a solar setup might be the way to go. We're planning to move OS soon after the trip so spending lots on installing things in the Paj is not something we want to do.
Kym
Reply By: Peter - Friday, Dec 03, 2004 at 16:35
did not know it was available for hire where from
AnswerID: 87170
Reply By: Davoe - Friday, Dec 03, 2004 at 16:41
have you considered one of those cheap chinese gennys - a bit noisier sure but that would be the most cost effective way between 100and 150$ I dare say cheaper than hiring
AnswerID: 87173
Reply By: Gossy - Friday, Dec 03, 2004 at 16:51
I personally would not go away without a deep cycle battery. I think you would regret it a week or two into the trip. If you are willing to spend 8 weeks of fuel then getting a dual-battery setup is petty cash.
AnswerID: 87179
Reply By: Taize - Friday, Dec 03, 2004 at 16:57
I've realised that my initial post was a little confusing.
I do want to get a second battery. Because we have young kids we wont be doing the 7-8hrs of driving needed to bring the battery back to full charge. Hence, I;m thinking of going solar for charging the battery.
So, all I would need to hire (or borrow) would be the solar pannels and regulator.
I hope that clears things up a little.
Kym
AnswerID: 87180
Follow Up By: Member - Jimbo (VIC) - Saturday, Dec 04, 2004 at 08:59
Kym,
I you use and AGM as your second battery it won't take 7-8 hours per day to charge (that's only for wet cells). A short drive or two each day or idling the motor 3 or 4 times a day (as long as you're not near people who may be upset by the noise) will do the trick.
I would also suggest getting a cheap multi meter to check the voltage to ensure it never gets below 12 to ensure you don't overwork the battery.
Jim.
FollowupID: 345985
Reply By: drivesafe - Friday, Dec 03, 2004 at 19:21
Hi Tiaze, I posted a reply on the other site.
Could post some idea of what you are going to use the power for.
AnswerID: 87202
Reply By: Member - Pesty (SA) - Saturday, Dec 04, 2004 at 07:07
Taize, most of your draw will be your fridge, and the longest time without going anywhere is night so solar will be of little use, why not get a protable power pack ?
I would be using the a good gen set, not a cheapy as the good ones are very very quiet, and run it part of the day when stopped, and if you flatten your battery, you can charge it up a bit to get car started, in a reasonable short time, and your on your way , but if its overcast and your batt is flat, you may not go anywhere, as solar is much slower, trickle charge . Gen set a dam site easier carry than large solar panels.
AnswerID: 87243
