storeing unused energy
Submitted: Sunday, Dec 05, 2004 at 21:12
ThreadID: 18343 Views:2262 Replies:4 FollowUps:2
Following on from jimbo,s question on solor power. I think that I waste power
my panels generate ie batterey only getting 3-4 amps through the
regulator,indecateing the batterey is charged when if batterey was low I could get 8-9 amps.
the batterey I use is a trojan scs225 130ah. The question is? Can I get another
batterey of the same, hook them in series ( I think) to double the ah,s.
Hope you can understand what I am trying ask.
Cheers brian
Reply By: Bonz (Vic) - Sunday, Dec 05, 2004 at 21:36
Brian, Storing unused energy is the bain of all mankind, especially electrical energy. You could go get another battery, connect it in PARALLEL not in series, and then charge that up also. Question is....do you need to? A 130ah battery is quite large and unless you need additional power from a second battery, don't sweat it, you're not really wasting energy, just replacing what you use.
AnswerID: 87382
Reply By: Topcat (WA) - Sunday, Dec 05, 2004 at 21:48
Depending on what you are using your deepcycle battery for (i.e. current drawing rate on your accessories) you will increase your storage capacity if you connect up a second battery in parallel. It is best to do this setup with 2 x new batteries otherwise isolate them and rotate your power selection so that your solar panels can charge the one off-line. It is recommended by some Solar Power suppliers to leave your panels permantly connected via a suitable regular so that your battery when fully charged remains in that state when not in use. I use a set-up using a "Puilse" regulator which sends a pulse current to the battery when it is fully charged to reduce the 'sulphation' which deteriorates the cells in all lead acid batteries during discharge cycles & subsequently increases the life of your battery. Just because you have a solar power setup which is not being used to full capacity doesn't necessarily mean you go and spend money on a second battery for the sake of getting the max out of your panels if you really don't need to. It is always better to have some in reserve. Hope this helps in your decision. Cheers
AnswerID: 87383
Follow Up By: Member - Brian (WA) - Sunday, Dec 05, 2004 at 23:08
thanks topcat&bonz
Its just the thought of not getting all that energy stored. as i said i run 2x40 engels& and two fluro,s for maybe 2 hrs at night.in winter you tend
to get into bed earlier. I do hook up the batterey in the camper every
3-4 days brian
FollowupID: 346189
Reply By: David Au - Monday, Dec 06, 2004 at 01:06
Brian if your battery is still taking 3 to 4 amps, it is doubtful it is fully charged.
AnswerID: 87398
Reply By: Lone Wolf - Monday, Dec 06, 2004 at 07:40
Just take a look at my belly....... now there's a LOT of stored energy!!
Wolfie
AnswerID: 87403
Follow Up By: Member - Jimbo (VIC) - Monday, Dec 06, 2004 at 19:17
Or take a look at my Willy.
There's a lot of underutilized energy.
Jim.
FollowupID: 346284
