Troopy Front Suspension
Submitted: Wednesday, Dec 08, 2004 at 11:09
sang
Hi there,
I have a 96 75 series troopy. When jack up the front
wheels, there is a discernable play in the verical axis at top of tyre and none in the horizontal axis. Was told this be the upper swivel hub bearing faulty. Can the bearing be replaced without removing the hub, axle etc.
Many thanks for any response
Sang
Reply By: Well 55 - Wednesday, Dec 08, 2004 at 12:06
To me it sounds like the king pin bearings are worn, not so much that they wear its the needle rollers wear a grove in the outer cup. The whole lote has to be removed. hub, housing, front disc etc to get the bearings and cup out.
When replacing new bearings do the inner axle oil seal as
87757
Follow Up By: Member - Paul J (ACT) - Wednesday, Dec 08, 2004 at 12:24
G,day Tony, how ya goin?
346560
Follow Up By: Well 55 - Wednesday, Dec 08, 2004 at 14:42
Just like you mate FLAT OUT.
346582
