Second Battery, Mazda B2500 ute
Submitted: Thursday, Aug 29, 2002 at 00:00
ThreadID: 1842 Views:2327 Replies:3 FollowUps:0
I want to put a second battery in my2000 Mazda B2500 diesel. The quotes I have had are very expensive. Is a fancy isolator needed or are there simple systems which work.
Reply By: Marty - Thursday, Aug 29, 2002 at 00:00
G'Day Phil,
A simple and cheap way is to fit your second battery in a cradle wherever you can and link the two battery's together, putting a simple isolator switch on the positive lead between them.
You still run everything off your main battery but disconnect the isolator when stationary for any extended period of time using power ie.fridge, lights, stereo ect.
Before starting your vehicle, re-engage the isolator switch so the second battery effectively jump starts your vehicle.
Standard 60 series Landcruiser set-up.
Regads,
Marty.
AnswerID: 6143
Reply By: Des - Friday, Aug 30, 2002 at 00:00
I would just get someone to check the type of alt that you have, long term/sort term the wrong setup can do damge to it. Not saying don't do it, a little money spent now etc etc...
AnswerID: 6150
AnswerID: 6151
