Water Drums
Submitted: Monday, Dec 13, 2004 at 18:27
Member - Nick (TAS)
Have sold our
water bladder(thanks EO trader section) and am about to get a couple of
water drums.Last year we used 25lt drums(jerry can shape) on our holiday but have recently seen 25lt squat drums that would fit on the floor under the kids feet nicely,BUT
I know petrol drums are red,
water clear/blue and diesel Blue but is there any differance in these drums,like do they all have the same plastic construction and so on.CAN you use any of these for
drinking water(all new drums) as the one's I want are coloured red.
I take it they are only coloured so you know whats in them at a glance?
Reply By: crfan - Monday, Dec 13, 2004 at 19:03
Diesel drums are yellow.
Are you talking about the 25l outboard fuel
tank red plastic drums( scepter brand is one)?
P
88557
Follow Up By: Member - Nick (TAS) - Monday, Dec 13, 2004 at 19:26
Yep ment yellow,not blue for
water and diesel.They're like outboard tanks I spose without the fuel fittings but that shape.
347422
Reply By: Robbg - Monday, Dec 13, 2004 at 19:06
I'm not sure whether the colors do more than indicate the contents (BTW I think diesel is usually stored in yellow containers). The fuel containers seem more heavy duty than those for
water, and they often have two holes at the top - one for pouring and the other to let air in as you pour. The main problem will be that if you're using containers made for fuel you won't get the threaded hole in the bottom into which you can screw a tap. The good news is that square 25lit
water containers are cheap at either Rays Outdoors ($16) or Granger's
Camping World ($15), not sure if Granger's is in Tassie. Plastic screw in taps are about $2 each.
Rob.
88560
Follow Up By: Member - Nick (TAS) - Monday, Dec 13, 2004 at 19:24
Just re-read what I wrote and yep stuffed up ,ment yellow for Diesel not blue.
347421
Reply By: Member - Bernie. (Vic) - Monday, Dec 13, 2004 at 19:15
Hi Nick ..You see lots of red drums & jerries .... usually containing FUEL of some discription.
Don't know how old your kids are but they could by mistake drink from or think someone elses red drum contained
water, not a nice thought.
Could also be a different type of plastic as the white or blue or green plastic should be a food grade quality.
88565
Follow Up By: Member - Nick (TAS) - Monday, Dec 13, 2004 at 19:30
Thanks Bernie,didnt think about that one(kids drinking out of drums).
Thats what Im wondering,different plastics for different coloured drums.
347423
Reply By: Mark R - Monday, Dec 13, 2004 at 20:06
G'day Nick,
Don't want to be a party-pooper but can I suggest you don't carry a (potentially) 25Kg missile under your kid's feet or anywhere in the unprotected passenger compartment. Should only be stored outside the passenger compartment or behind strong cargo barrier.
Best wishes and safe traveling
Mark
88573
Follow Up By: Member - Nick (TAS) - Tuesday, Dec 14, 2004 at 13:22
Thanks Mark,all
water containers in vehicle are strapped to the floor.
347493
Reply By: Shaker - Monday, Dec 13, 2004 at 23:53
I believe
water drums are manufactured from 'food quality' materials. Which means that they impart no flavour or chemicals to the contents!
88618
Reply By: Gajm (VIC) - Tuesday, Dec 14, 2004 at 08:38
If they actualy state they are ok for fuel then they are not ok for
water. They are made from different types of plastic, and the fuel ones should not carry
water and vise versa. I am off to see if I can find the article I read, but the gyst of it was the chemicals in the fuel resistant plastic would contaminate
water.
88636
Follow Up By: Member - Nick (TAS) - Tuesday, Dec 14, 2004 at 13:24
Just what I wanted to hear , thanks Gjam and shaker.
347495
Reply By: Member - Stillthinkinaboutit - Tuesday, Dec 14, 2004 at 08:45
If you are after 20L - 25L square drums, why not see the cellarman at your local PUB or Club. Get a couple of bulk spirit containers, rinse them out and you have good
water containers, they even have the bung in the bottom that you can remove and fit a tap into.
88637
Follow Up By: Member - Nick (TAS) - Tuesday, Dec 14, 2004 at 13:25
Will check it out.
347496
