2nd Battery in a hilux tray
Submitted: Saturday, Dec 18, 2004 at 17:22
mikeyandmary
Hi all,
If I am installing a second battery into the tray of a ute, what is the best way to route the cable from the engine area to the tray? Can it go inside the chassis rail? I will be running 4AG cable inside the black split tubing stuff. I have a 91 dual cab hilux.
Thanks Heaps and Merry Christmas...
Michael
Reply By: Mad Dog (Victoria) - Saturday, Dec 18, 2004 at 18:31
Run it anyway you like Mike as long as it's
well protected. I took
mine along the top and side of the chassis rail.
89393
Follow Up By: Steve - Monday, Dec 20, 2004 at 08:22
Same here.
But I ran it in some of that flexible black tubing.
348394
Reply By: Member - Athol (NSW) - Saturday, Dec 18, 2004 at 19:25
Mike, I ran 16 square mm welding cable through the chassis to the second battery in the camper, that stuff has double insulation and should stand up to wear and tear.
Athol
89395
Reply By: Allan-TPWA - Sunday, Dec 19, 2004 at 10:54
Michael
Added to what was said, bring the cable through the back of the tail lights if you are a bit nervous about drilling holes. With the cable, go big. Even with 16 sq mm you may get 0.5 v drop.
89447
