shudder in wagon
Submitted: Monday, Dec 20, 2004 at 12:16
Chel
Hi, Just wondering if anyone may have heard of this problem before. We have a 97 2.8TD patrol wagon. With clutch half out it shudders and mainly in the hot weather. Any ideas? Thanks
Reply By: 3.0turbob - Monday, Dec 20, 2004 at 12:24
Sounds like the clutch is shuddering as it takes up, so,.. it is most probably worn.
7 years old, what sort of mileage? Take it to your mechanic to get checked out.
89564
Reply By: Member - Hugh (WA) - Monday, Dec 20, 2004 at 15:42
Chel,
I just changed my clutch on '99 2.8 TD Patrol. Noticed it slipping slightly, then shudder on pedal take-up like you have described. When I changed the clutch there was 0.2mm clearance left between rivet heads and pressure plate.
If you do a search you'll find my post on the topic and prices / part numbers for replacement clutch kits.
Regards,
Hugh
89582
Follow Up By: Chel - Wednesday, Dec 29, 2004 at 11:42
thanks to both 3.0turbob and hugh (WA), car booked in.appreciate the time to post to me
349227
