bullbars
Submitted: Wednesday, Dec 22, 2004 at 14:31
stans truck
hi all all new to this ok just bought a toyota land cruiser 1999 modle and its naked,never been on a dirt road yet.need to know what kind of bar would be the best ,some people say steel like arb ,or alloy bar .have sent a email to a company east coast bullbars they make a verry nice bar and only make alloy bars they seem to think thats the way to go ,talked to a guy here in
adelaide who use to make bullbars and he says not to get a steel bar becuse they are to heavy and cause front end problems wich he has seen a lot of please can you advise me regard stan.
Reply By: slyonnet - Wednesday, Dec 22, 2004 at 14:52
Hello Stans Truck,
you are right steel bars can get heavy and cause your nose to point down, affecting your departure angle, where alloys are less prone to it. Another problem with the steel bars is rust once you get some chips on the coating (and trust me you will if you ga on the dirt). On the other hand they are stronger than the alloy bar I think.
You can probably correct the problem of weight by modifying your
suspension but there is cost involved.
I personnally don't think there is much difference other than that between steel or alloy bars and for me it mostly came to a choice of how will it look on the car. I had a steel bar on my old Courier and it looked good (white car and black coating on the bar) and did not seem to point my nose down, especially when the ute was loaded at the back. But it started to rust wherever the coating had wore out. On the new Challenger I opted for an alloy East Coast Bull bar (they really look awesome). Reason is the car is a metallic silver color and it looks better than a black coated bar. Plus for the most recent Challenger models the choice is rather limited. Some bars did not come done low enough to cover the wind screen whipers
water tank,...
I don't know if it could be a problem for your vehicle but there are also things like that to consider (anything not covered, is it winch compatible, where can you fit your recovery points, can it hold your spotlights, antennas,...).
I hope this help and good luck,
Slyonnet.
89919
Reply By: Member - Alan - Wednesday, Dec 22, 2004 at 16:17
Have just been through a similar exercise myself and weight was one reason I opted for an alloy bar for our Prado. Whilst not answering your question I did have it powdercoated, polished bars look good when new however the upkeep can be very time consuming.
Mine is powdercoated in a hammertone type dark grey/black colour called Mystique (i think) which sets off
well against the silvercolour of the car. Upkeep is minimal , a wash when the car gets a wash and if you happen to chip it a black permanent marker is a good touch up pen.
Just my two bobs worth
Alan C
89935
Reply By: Crackles - Wednesday, Dec 22, 2004 at 17:26
Stan,
If you intend to play hard in the bush a steel bar is the go. Weather you just knudge a tree or run into something it will take a beating & is easily repaired. A winch is also mounted alot more securely in a steel cradle. (Saw an electric winch pulling it's self off the front of an alloy bar recently) You would probably need to upgrade
the springs to carry the extra weight.(definately with a winch)
Alloy bars can be fitted without the need to upgrade
the springs but if damaged are difficult to fix (throw away) & often suseptable to cracking on the mounts which is hard to weld up in remote areas.
ECB make excellent alloy bars & racks & IMHO are one of the better ones.
Another option is the Sahara style bars. Steel but with the loops chopped off to save weight.
Cheers Craig........
89941
Reply By: stans truck - Wednesday, Dec 22, 2004 at 17:58
ok guys thanks for your advise hope you all have a merry xmas and ahappy new year
89951
Reply By: merlinp - Wednesday, Dec 22, 2004 at 18:28
Hi Stan
Have you given any thought to a "smart bar" made from the same stuff as wheely
bins very tough and light and reshape after a hit. www.smartbar.com.au.
merlinp
89957
Follow Up By: Truckster (Vic) - Thursday, Dec 23, 2004 at 09:46
Great for attachin
winches to and brilliant for recovery points.
LMAO plastic bars....
348793
Reply By: muzzimbidgie - Wednesday, Dec 22, 2004 at 18:55
Hi Stan, you will find that if you opt for a steel bar, it makes using a kangaroo jack, or hi-lift, jack possible without too much damage to your barwork. If you intend to takle serious off-roading, it may be wise to have one of these.
Also, fitting better coil springs to a 100 series cruiser is not very expensive. You should be able to get a set for about $250 a pair (fitted).
Try a spring /
suspension place, they're cheaper than a 4x4
shop. Not only will these lift your cruiser a bit, it will handle much better.
If you're only going mild, not wild, then ally is tops.
Muzz
89960
Reply By: Member - Davoe (WA) - Wednesday, Dec 22, 2004 at 19:14
I have run over in ecxess of 8 roos in my camper and laid flat countless thousands of trees in work tojos so I can tell you if it isnt steel its just for show - save your money
89962
Follow Up By: Crackles - Thursday, Dec 23, 2004 at 23:14
Hey Davoe,Tread lightly & give our native wildlife a go ;-)
348901
Follow Up By: Member - Davoe (WA) - Friday, Dec 24, 2004 at 10:18
yea i hear you on the surface it does look like a redneck post - the sort that gives us a badf name. But I live in Kalgoorlie and alot of my travels involve taking off straight after work due to distances I have to travel just to get to
the beach etc. This makes animal strikes a fact of life. As for the trees that was my job when working for government mapping geos. Alot of our work was done se of
Norseman in dense bush with little or no tracks so bush bashing was just part of the job. Click on my rig profile and check out the last photo - that was just a typical day in the office. Have a good break
348930
Follow Up By: Crackles - Friday, Dec 24, 2004 at 11:44
I thought that may have been the case. The mapping sounds like a top job & a great way to see some remote areas us mere mortals only dream of. Just as a matter of intrest, what tyres did you use offroad to minimise staking? Cheers Craig...............
348939
Follow Up By: Member - Davoe (WA) - Friday, Dec 24, 2004 at 12:05
yea it was a great job - paid to 4wd and
camp but the pay was lousy. we used dunlop dr2 12p tyres could not speak highly enough of them. I could not even describe to you the punishment these things took driving over deadfall and burnt areas I went 2 weeks of bashing (like in the photo and worse) without a flat however that was in fairly sandy areas. As we worked our way north and harder ground there were more flats. They did meet there match in my last week over burnt out areas with 20cm high stakes as sharp as razors 11 flats in 5 days. They are crap in mud but for cross country driving I would buy/recomend them
348942
Reply By: Member - Rob J (WA) - Wednesday, Dec 22, 2004 at 21:49
G'day Stan,
If you get a Smart Bar don't get it colour coded.
W've got one on our Falcon ute, hit a roo, didn't damage the bar but with it absorbing all the shock it splintered the paint and now it looks shocking.
89987
Reply By: Smudger - Thursday, Dec 23, 2004 at 10:52
Big chunky alli bars look sexy, but mostly you can't un bend 'em. Steel for me always.
90031
