GQ Front end wobble
Submitted: Sunday, Dec 26, 2004 at 21:53
ThreadID: 18878 Views:3205 Replies:7 FollowUps:0
How ya going
wondering if anyone can help
my GQ 4.2l Petrol 91 model has recently developed a major front end wobble
when traveling at over 70km per hour. Orriginally it didn't do it until 100km p/hr but it is getting worse. It isn't a tyre problem cause i have just had them replaced. Has anyone had this trouble, if so can you help me out. thanks, Mike
Reply By: Member Eric - Sunday, Dec 26, 2004 at 21:58
Is it after a bimp in the road ? usually the steering damper lets go and creates this
AnswerID: 90403
Reply By: ianmc - Sunday, Dec 26, 2004 at 22:58
One possibility is lack of castor at front wheels. Used to insert tapered wedges between spring & axle to correct this but with coils needs different approach.
It can become very dangerous & loss of control can be severe.
Maybe theres other probs that GQ folk will pass on!
AnswerID: 90413
Reply By: Bob Y. - Qld - Monday, Dec 27, 2004 at 08:26
Mike,
Badly worn tie-rod ends will produce a wheel wobble as you described as well.
Also how long since the king-pin bearings have been replaced? Once the cups are worn badly, the rollers dropping in and out of wear grooves manifests as a wobble, or causes vehicle to wander, needing constant correction.
As Eric said, steering damper can cause similar probs. Best way to check tie-rod ends, is to park with one tyre up against kerb, and get somone to move steering wheel back and forwards, while you observe any movement in joints. If they are really worn then it's very obvious.
If king-pins are knackered, then you'll have to get your hands dirty!!
Hooroo...
AnswerID: 90432
Reply By: Truckster (Vic) - Monday, Dec 27, 2004 at 09:42
first thing to do, put your rear wheels on the front go and drive it..
If the vib is worse when you hit the brakes, try panhard bushes.. That happed to mine few weeks ago.
Nissan will try and flog you the whole panhard, but the rear bushes are same as front.
I have part # if u need :)
Again as others have said, wheelbearings, caster bushes.
AnswerID: 90441
Reply By: Member - Brett H (QLD) - Monday, Dec 27, 2004 at 21:54
I saw a lady in Kmart with this problem.....hahaha
AnswerID: 90498
Reply By: Mike GQ - Tuesday, Dec 28, 2004 at 18:31
thanks guys for ya help, ill keep all your views in mind when i have a look tomorrow,
cheers mike
AnswerID: 90557
Reply By: duncs - Tuesday, Dec 28, 2004 at 22:14
Mike GQ,
Had exactly the problem you describe. I spent a fortune on all kinds of supension/steering repairs/mods over a period of about 2 years before I found the problem.
It was a worn bush in the panhard rod. Cost me $50 and half an hour at Pedders in Dubbo.
I would start looking there.
Duncs
AnswerID: 90586
