RESTORE BBQ PLATE
Submitted: Monday, Sep 02, 2002 at 00:00
ThreadID: 1891 Views:7210 Replies:6 FollowUps:1
HOW DO I RESTORE AN OLD BBQ PLATE THATS RUSTY
Reply By: Steve - Monday, Sep 02, 2002 at 00:00
Get a "grill stone" from a catering 'mob' and use it to grind the surface back to a smooth even finished / polished plate --- easy ... been there many times !
steve
AnswerID: 6288
Reply By: allyn - Monday, Sep 02, 2002 at 00:00
after it's cleaned keep using it and the oils/fats will keep the rust at bay.
DON'T use detergents to clean it either.
AnswerID: 6291
Reply By: kezza - Monday, Sep 02, 2002 at 00:00
molasses will remove rust - old parts restorers trick - may need to soak it for 2 weeks.
kezza
AnswerID: 6296
Follow Up By: Pirvine - Tuesday, Sep 03, 2002 at 00:00
I have seen molasses used to remove rust from Axe heads. Diluted slightly I think. The heads were left with clean metal ready to polish. Phil
FollowupID: 2781
Reply By: bob - Tuesday, Sep 03, 2002 at 00:00
you could try a wire brush attachment on a grinder or if its real bad get it sand blasted
AnswerID: 6314
Reply By: royce - Wednesday, Sep 04, 2002 at 00:00
Use it use it use it. Leave it crusty. Feed the kids first. They get the crispy snags, cooked on the cherry red surface... black on the outside, toothpaste on the inside. Then fling on the steaks. Yum , but a bit hard to eat with a tongue in your cheek... cheers Royce
AnswerID: 6375
Reply By: johnsy - Wednesday, Sep 04, 2002 at 00:00
drag it up a sandy creek or dirt road if it's steel if it isn't get steel cya johnsy
AnswerID: 6376
