Site Search
Section Image
can an old gas bottle used as air reservoir?
Submitted: Sunday, Jan 02, 2005 at 09:49
time waster
i'm looking at buying an arb air compessor and permantly mounting it under the bonnet. i know they are not a real fast at there air flow rate 24Lpm but the price is in my range $255 and down the track will fit front air locker my question is what to use as an reservoir tank have seen people use fire extinguisher bottles but i have a d/cab luxi and have two pockets either side of the rear wheels under the tray that i could fit two 4.5kg gas bottles, can old gas bottles be used as air reservoirs? thanks!
Advertisement
ThreadID: 19000 Replies: 10
Views: 1238 FollowUps: 4
AnswerID: 90999   Submitted: Sunday, Jan 02, 2005 at 10:58
Member - Ed. C. replied:
G'day time waster,
The gas cyls are rated pressure vessels, tested to 3.3 MPa (approx. 450 psi), so I can see no reason why they can't be used as air reservoirs (holding what, around 100 psi ??)...
In fact, I have done just that, mounted on the A-frame of my C/T, & used mainly for re-inflating tyres...
You'll need to make provision for a water drain outlet, which will mean drilling a hole & welding (or brazing) a suitable fitting, which in turn will mean that the test rating will be null & void (unless you have it re-tested)...
Just make sure there is no rust inside, & if you're gunna be applying any heat, then make sure there ain't no residual gases in there!!!
When I "modified" mine, it had been empty for like, many years, so there was no drama...
Regards, Ed. C.
Click Image to Enlarge
Confucius say.....
"He who lie underneath automobile with tool in hand............
Not necessarily mechanic!!"
Reply 1 of 10
FollowupID: 349599   Submitted: Sunday, Jan 02, 2005 at 15:11
Banjo (SA) posted:
Ed - if mounted upside down, could the fill on the cylinder double as a water drain ?
By the time I'm too old to go bush, I'll have all my gear set up just right !
FollowUp 1 of 2
FollowupID: 349600   Submitted: Sunday, Jan 02, 2005 at 18:09
Member - Ed. C. posted:
G'day Banjo,
The problem I see with that approach, is that you'd be drawing air from the bottom of the tank, which is precisely where any condensation/water will collect... Not a good idea, IMO...
I had no qualms about welding the extra fittings for water drain & relief valve/pressure gauge on mine (using low-hydrogen electrodes)...
It holds pressure indefinitely, so there is obviously no porosity in the welds, therefore (presumably) no weakness there either..
(After all, how is the original threaded valve fitting attached??)
Regards, Ed. C.
Confucius say.....
FollowUp 2 of 2
AnswerID: 91006   Submitted: Sunday, Jan 02, 2005 at 12:36
Rick Blaine replied:
I used one as a reservoir for air for many years.... I suggest that you rinse the interior with some turps or thinners then put some cold gal paint inside and swill it around to "Paint" the inside and it will resist internal corrosion well
Reply 2 of 10
FollowupID: 349598   Submitted: Sunday, Jan 02, 2005 at 14:15
Excellent idea!!
(coating the inside as you describe)...
Now why didn't I think o' that???
I'll hafta add it to my "Gunna-doo" list... Thanks for the tip...
Regards, Ed. C.
Confucius say.....
AnswerID: 91011   Submitted: Sunday, Jan 02, 2005 at 15:49
gforse replied:
what a great idea thanks for the idea we have a dual cab lux as well am going to do same thank you very much even the missus said excellent garry karen
Reply 3 of 10
AnswerID: 91019   Submitted: Sunday, Jan 02, 2005 at 17:23
Member - Mark W (VIC) replied:
time waster
I was looking to do this, was in town at George Taylor Store ( Vic ) and they had ex Army air tanks with inlet outlet and drain all ready to go for $20.00 about 4 inch by 2 foot long fits behind bull bar or underneath easily. Worth a look ??
Mark
Reply 4 of 10
FollowupID: 349639   Submitted: Monday, Jan 03, 2005 at 08:19
Member - Bernie. (Vic) posted:
Hi Mark do you have an address for George Taylor (Vic) I cant find one ?
Prado TD Auto
Yes thats my girl at the wheel.
Activities Index
Make Your Own Blend Experience Make Your Own Blend Experience
The Barossa - SA
Try your hand at being a Winemaker on this fun and interactive Penfolds 'Make Your Own Blend' experi
Hawaiian Lomi Lomi & Facial - 2 Hours Hawaiian Lomi Lomi & Facial - 2 Hours
Sydney - NSW
Unwind in deep tranquillity and feel your body rejuvenate to its very best.
Premium Gliding Air Experience Flight  - Sydney Premium Gliding Air Experience Flight - Sydn
Sydney - NSW
Soar like an eagle high above the picturesque Camden valley, with views to the Sydney skyline and th
Tandem Paragliding Tandem Paragliding
Illawarra - NSW
Tandem Paragliding is fun and exciting.
Book Now - Things To Do
AnswerID: 91067   Submitted: Monday, Jan 03, 2005 at 08:06
Nick R replied:
A problem with welding them could possibly (I might be wrong) be a risk of explosion. not sure about cylinders but I know with fuel tanks, they need to be de-gassed for a time first to ensure no fuel remains.
Our local mechanic has a heap of old cylinders, yours might too, which held inert gasses which would be safe for welding.
I'm interested in doing the same, let me know how you go.
NickR
Reply 5 of 10
AnswerID: 91078   Submitted: Monday, Jan 03, 2005 at 09:48
time waster
the web address for GTS is www.georgetaylorsstores.com.au
Good luck if you need any help get back to me
Mark
Reply 6 of 10
AnswerID: 91184   Submitted: Monday, Jan 03, 2005 at 20:58
GRAEME replied:
If you go to a truck wreckers you can get an air tank of almost any size.
I got one for $15 with fittings at both ends, a drain valve and brackets.
It's about 5 or 6 litres and mounted nicely on the gearbox crossmember.
I use a rattle gun all the time using an a/c compressor.
Graeme
Reply 7 of 10
AnswerID: 91238   Submitted: Tuesday, Jan 04, 2005 at 09:40
Rod W replied:
Agree with Graeme. Pick-up/use one from a truck wrecker.
Reply 8 of 10
AnswerID: 91285   Submitted: Tuesday, Jan 04, 2005 at 14:07
Member - Jeff M (WA) replied:
I bought one form Michigan Trucks in america when I ordered my air springs. www.trucksprings.com
Works a treat, was only about $25 new and get's HEAPS of use blowing my very very loud air horns, raising and lowering the back suspension and blowing out air filters while on dusty trips.
#1 - I'm not telling :-)
#2 Yellowdine National Park
#3 Powerline Trek - Saywers Valley
#4 Near Hyden WA
#5 Pinjar Pines
Reply 9 of 10
AnswerID: 91383   Submitted: Wednesday, Jan 05, 2005 at 07:24
Member - DOZER replied:
Gday
The gas cylinder is a good idea, and the gas bleed valve could be used to relieve water....the 9 kg models also have a relief valve on them should a pressure switch not work effectively...having said that, i use old dry powder fire extinguishers. They are rated to 200psi, and the alloy tops are easy to tap out 1/8 bsp, holes are already there, and some threads aswell.
The nearest scrap place will have one hundred at least/..
b4 you bag me out, walk a mile in my shoes, then your a mile away and have my shoes :)
Reply 10 of 10
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
