Thermo Fan
Submitted: Thursday, Jan 06, 2005 at 09:17
ThreadID: 19108 Views:2271 Replies:5 FollowUps:2
Hi Folks
Is the fans thermo coupler on a 1994 4.2td Nissan the type that you can fill silicon that is apparently sourced through Toyota
Thanks for the help
Ray
Reply By: Truckster (Vic) - Thursday, Jan 06, 2005 at 09:31
Yes, any TD42 one can be rebuilt.
AnswerID: 91547
Reply By: Kiwi Ray - Thursday, Jan 06, 2005 at 10:22
Hi truckster
Thanks for that
Ray
AnswerID: 91558
Follow Up By: Truckster (Vic) - Thursday, Jan 06, 2005 at 15:05
Yota maynot know it, the local one didnt.
Part #: 088161001 $11.00 per bottle.
FollowupID: 350248
Reply By: Member - Davoe (WA) - Thursday, Jan 06, 2005 at 10:23
did this job only the other week BUT these coments apply only to an 80 series fluid coupler however they should be of simular desighn
1)removing coupler is easy 4 bolts that hold it to the water pump pulley no belts need removing however you may need to remove the radiator shroud to take out the coupler including fan
2)seperate fan and coupler
3)go to toyota dealer and ask for the silocone oil (about 10 - 11$) I used 1.5 tubes
4) rumer has it some fluid couplers have bungs 80 series tojos do not so I seperated the 2 halves. They are held together by about 8 philips heads screws DO NOT ATEMPT DO UNDO THESE SCREWS WITHOUT AN IMPACT DRIVER LIKE I DID) you may round them
5) squeeze as much oil in as you can
6)reassembly oppisite to pull down
worked for me. Another option is to go to coventrys and buy another aftermarket unit for around$200
AnswerID: 91559
Reply By: Member - Roachie (SA) - Thursday, Jan 06, 2005 at 16:12
The only thing I can add to that is when i pulled the 2 halves of the one off my GU apart, the long, thin rubber "O" ring/gasket gizmo expanded and i couldn't get it back into the groove from which it came. It is about 1" (25mm for you young blokes) too long.
I've still got the whole hub at home, but bought a new one from Nissan for about $320-. I'd actually done that first and pulled the old one apart in an effort to learn how they work and possibly rebuild it for next time. I haven't tried to buy a new rubber for it yet, but someone on here told me that the type of rubber that is used in these sorts of applications is designed to expand once it's been used so that it will fill the area it's designed for; making it a throw-away item once it's been removed.
AnswerID: 91622
Follow Up By: Member - Davoe (WA) - Thursday, Jan 06, 2005 at 16:34
yea it was a bit awkward to get back in but doable (toyota)
FollowupID: 350290
Reply By: Kiwi Ray - Friday, Jan 07, 2005 at 11:35
Hi Every One
Thanks for the tips, I will attack it this afternoon.
Ray
AnswerID: 91754
