New Waeco
Submitted: Tuesday, Jan 11, 2005 at 10:33
ThreadID: 19253 Views:2217 Replies:2 FollowUps:4
Have just noticed on the right hand side of the Forum page that the new 40 ltr say's 12/24/240V, does that mean that you no longer require a transformer?
Reply By: Well 55 - Tuesday, Jan 11, 2005 at 11:37
That's what the blurb reckons, comes as standard. About time.
AnswerID: 92363
Follow Up By: Shane (QLD) - Tuesday, Jan 11, 2005 at 12:11
Yeh ! Just looked at the Waeco site, another $70 for the privilage. I guess the rest of the range will follow.
FollowupID: 351228
Reply By: Nudenut - Tuesday, Jan 11, 2005 at 12:38
the fridges can use either 12 or 24v and is automaticaly detects the voltage by the electronic module of the compressor. This way trucks etc etc can also use them.....
I would imagine most of us would use 240vac - 12vdc volt option
AnswerID: 92379
Follow Up By: Member - Raymond - Tuesday, Jan 11, 2005 at 14:09
Hi Nudenut
All the fridges with danfoss compressors can handle 12 or 24 volts as this is already in the electronics, so they have just added a 240 to 12/24 power supply to the fridge.
Engel have 12 or 240 volt but need an adapter for 24 volts
Others I am not sure of
Ray
FollowupID: 351268
Follow Up By: crfan - Tuesday, Jan 11, 2005 at 16:30
The newer engles are 12/24/240v no adapter.
FollowupID: 351337
Follow Up By: Nudenut - Wednesday, Jan 12, 2005 at 07:52
yes Ray I know the Danfoss can either use 12 or 24v and I know all that is needed is a 240v to what ever....but what does Waeco supply?....240v - 12 or 240 - 24 as a stepdown power supply?
for ease I went with 240 - 12 as components were more readily available to build.
FollowupID: 351460
