Site Search
Section Image
jackaroo roof rack and gearbox breather
Submitted: Saturday, Sep 07, 2002 at 00:00
Steve
Could anyone suggest a suitable roof rack for a jackaroo.I have a Rola track mounted one at the moment but it flexes the roof when I carry something a bit heavy.Maybe one that attaches to the internal roof gutter which seems to be the most solid point would be the one.Also where are the breathers for the gearbox and transfer case located.I cant find them.
Advertisement
ThreadID: 1934 Replies: 4
Views: 831 FollowUps: 1
AnswerID: 6458   Submitted: Saturday, Sep 07, 2002 at 00:00
Col replied:
Steve,
If you are carrying a load too heavy for a Rola rack on your roof I would be concerned! Rola, Rhino, ARB, TJM and Oval all have racks that that mount to the three existing mounting points. They are all commonly available.
Col
Reply 1 of 4
FollowupID: 2898   Submitted: Monday, Sep 09, 2002 at 00:00
Geoff posted:
Hi Steve just as Col said under the black strip that runs along the roof there is tape thats been painted over in 3 places, under the tape are holes were the Rhino brackets fit in to.I can stand up on the roof in any one of these points without the roof flexing. I carry a roof top tent and my wife and I sleep up top without any problems. What you have said about the roof flexing is why I got the Rhino set .
Regards Geoff
AnswerID: 6459   Submitted: Saturday, Sep 07, 2002 at 00:00
Darian replied:
Steve ....there is a breather point on top of the gearbox on my 99 TD. Handles gearbox and crankcase too far as I know. Lifted my console and gearshift boot to get in there (if I remember right) when I did this central lot plus the diffs - couple of years back now - rear diff breathes right up into the rear pillar - front terminates just under the rear of the bonnet - glued a lawn mower air filter onto the hose to keep dirt out on suck ins....cheerz..dp
Reply 2 of 4
AnswerID: 6493   Submitted: Monday, Sep 09, 2002 at 00:00
Emjay replied:
Steve,
There's another rack brand well worth looking at. Go to www.roofracks.com (no au) for an Aussie manufacturer of a brilliant system that looks like Rola but has a lot of points that I think are far superior. Their biggest advantage is the fact that you can switch them to almost any vehicle whereas the other systems are pretty inflexible. They're also stronger and cheaper (because they only sell direct). I've got them and they're the best I've ever had. If you tell them your vehicle model they make sure you get the bits to fit your mounting points.
Michael
Reply 3 of 4
AnswerID: 6591   Submitted: Friday, Sep 13, 2002 at 00:00
Steve replied:
Thanks for the reply to my enquiries.I have located the roof rack mounting points and they seem much stronger than the rola rack track mounts.To DARIAN I have removed the cover over the gearbox housing and found a rubber tube connecting two sections of the gearbox (probaly the gearbox and transfer case) with one end terminating near the passengers side of the transfer case lever and there is another tube fitting (with no tube attached) on the drivers side.Can you recall if this is the breather.I have been unable to find anything else that looks like a breather.I also have a 99 t/d Jackaroo and it sounds like you have been investigating the workings of it.I hope you can help.
Reply 4 of 4
Activities Index
Yoga Pass Intro for 5 Classes - National Yoga Pass Intro for 5 Classes - National
Sydney - NSW
Need to unwind and relax?
Luxury Yacht Romantic Overnight Stay for 2 Luxury Yacht Romantic Overnight Stay for 2
Sydney - NSW
A truly romantic experience.
Sydney Harbour Jet Boat Rush Sydney Harbour Jet Boat Rush
Sydney - NSW
Hop on board one of Sydney's fastest jet boats and enjoy a ride full of non stop action.
The Real Outer Barrier Reef Experience The Real Outer Barrier Reef Experience
Cairns and Tropical North QLD - QLD
An experience of a lifetime where we'll take you to an underwater world that's a dazzling kaleidosco
Book Now - Things To Do
