Hilux issues
Submitted: Tuesday, Jan 18, 2005 at 22:45
ThreadID: 19576 Views:6356 Replies:10 FollowUps:6
Hi guys , been back one day and the help calls are already started , a friend just got back from a outback trip towing a trailer and noticed his tub now is 1 to 2" further away from the rear window at the top of the tub than before the trip . Anyone else had a issue like this with towing in a hilux . He was told that his chassis has bent . So I asked that no one touch the car till i see it tomorrow. I find it hard to believe that you could bend the chassis on a hiliux towing a standard type trailer with bugger all weight on it .
Any previous experience with this issue guys and gals ?
Reply By: Glenno - Wednesday, Jan 19, 2005 at 00:03
I hit some big pot holes out west in our Hilux DC, so much so that the Tub moved enough to make the canopy leave big scratch marks on the back of the cabin. The gap from memory is normally about 2cm so thats a fair bit of movement. As to the chasis bending, maybe the mounts have bent where they attach to the tub etc?
Glenn.
AnswerID: 93866
Reply By: Tuff60 - Wednesday, Jan 19, 2005 at 01:22
As yet not seen a HiLux bend a chassis except where instant stops occur, like when a tree is used, have on the other hand seen lots of tubs on Luxs as well as others move or break thier mounts. Even a snatch so violent the Hilux, which was being streched between a 60 Series and a GU, ended up a 90 degrees to where it started, didn't even bend it. Did make the driver real angry though.
AnswerID: 93869
Reply By: GaryInOz (Vic) - Wednesday, Jan 19, 2005 at 01:28
Possibly the tub mounting bolt were a bit loose, allowing the tub to vibrate/walk itself backwards with bodyflex???
AnswerID: 93870
Reply By: Member - Sam (NSW) - Wednesday, Jan 19, 2005 at 09:14
I've had the mounting bolts work loose on my DC Hilux. And I would imagine that when loaded up, with the extra weight, there is a good chance of bending mounts etc when hitting large bumps etc.
AnswerID: 93887
Reply By: Mad Dog (Victoria) - Wednesday, Jan 19, 2005 at 11:00
Very uncommon for a hilux to bend the chassis but the boys from Africa tell me it can happen if grossly overloaded and abused. The hilux gets one hell of a battering in Africa As others have said the tub has probably moved. I wonder what ball weight was on the trailer though.
AnswerID: 93900
Reply By: Mad Dog (Victoria) - Wednesday, Jan 19, 2005 at 11:15
A wee bit off track Eric so I hope you don't mind me posting this but Tuff60 mentioned crashing a lux into a tree which reminded me of the BBC's efforts with testing the unbreakability of an old hilux. Can't really draw any conclusions apart from the fact that this particular truck didn't want to die and it makes interesting reading. There is some video of it floating around the web somewhere.
As you maybe aware the BBC's weekly motoring programme Top Gear recently
decided to test how tough these 4X4s are as the vehicle appears everywhere
in news reports serving a mutlitude of various roles all over the world
The base vehicle was a 15 year old heap purchased for about £1,200.00 less
that $2,000.00 from a farmer where it had had a hard life having clocked up
over 130,000 miles and the body work was showing it......
Test 1
Drive it at 30mph into a tree ( front right courner - driver's side in the
UK )
Result - Bent bull bar, broken light & front panel damage
Truck carries on
Test 2
Drive it around Bristol, an old industrial town.
Trough tight streets where it ripped out huge stones from 150 year old
walls, down lots of steps & generally bash it about
Result - some more panel damage
Truck carries on
Test 3
Drop it 30 foot from a crane
No damage
Truck carries on
Test 4
Drop a caravan on it from 30 feet
Result - Top lip of bed is bent
Truck carries on
Test 5
Trash the truck
No apparent Damage
Truck carries on
Test 6
The Wash
Strap the vehicle down to the pier in the Bristol Channel
This has one of the Strongest and fastes Tidal Flows in the British Isles
and wait for the tide to come in
Initial Damage
Windows blown out by tide
Then
The 3" diameter mooring ropes ( used by the Royal National Lifeboat
Institution ) tethering down the vehicle break under the strain and the
vehicle is swept out to sea.
Several hours later when the tide has gone out the vehicle is found several
miles away partially burried in the estury bed.
Vehicle is righted and after drying out & a bit of water dispersing oil &
some petrol poured directly into the carb it starts up.
Truck carries on
New windscreen put in so it can be driven legally on the road to.....
Test 7
Wrecking ball
Bash it around by swinging a wrecking ball into it.
Result - severe dent to rear tail gate.
Truck carries on
Test 7
Fire
Set light to interior & bed then stand well back
Return to truck after fire has gone out.
Result - Interior blackened - new windscreen cracked
Some minor tinkering & truck starts
Truck carries on
No major parts were replaced during or after any of the test.
Oils were checked & topped up if necessary
Only minor tinkering by 1 mechanic with the most basic tools was allowed
This week
Test 8
Demolition
Place the same battered old truck near the top of a 20 storey block of
flats
Then
Blow it all up
Truck falls over 150 feet along with building it is on
Wait for dust to settle
Unearth truck ( rather roughly with digger ) which is on its roof and roll
( several times ) it to the bottom of the pile of rubble some 30 feet
Result - Major body damage
Cracked chassis frame. Body work is holding vehicle & frame together
Some minor tinkering and truck starts
Truck carries on
Drives into Studio
The presenters suggested retiring the truck & putting on a platform as a
statue to its toughness which the whole audience agreed with.
AnswerID: 93904
Follow Up By: Member - Bradley- Wednesday, Jan 19, 2005 at 12:03
what a bleep er, can't imagine worksafe letting anyone here do the same :-(( . kind of reminds me of our exploits with my motarola 'slim brick' phone 2 days before they shut down the analog network --- phone carries on..
FollowupID: 352879
Follow Up By: Member - Jeff M (WA) - Wednesday, Jan 19, 2005 at 15:16
It was an absolutally awsome video, I saw it!
However they did not poor petrol into the carby as it was a 2.4 2L Diesel motor. They took the glow plugs out and turned it over to get rid of the water I belive. They also removed the battery before they put it in the ocean so they would not need to replace it (as they weren't allowed to).
They also drove it through a barn at high speed totally demolishing the barn and it didn't even slow down.
NO spare parts were allowed. There was a mechanic and he had a helper and they had a time limit to get the vehicle going after each test.
FollowupID: 352893
Follow Up By: greghud - Wednesday, Jan 19, 2005 at 16:15
i gotta see the video! anyone know where if how to download the vid of this? wot a laugh.
greg
FollowupID: 352905
Follow Up By: Bonz (Vic) - Wednesday, Jan 19, 2005 at 18:13
Cut and polish, transport to Australia, sell to Ray
Truck carries on!
Amazing story and totally believeable
FollowupID: 352925
Follow Up By: BenSpoon - Saturday, Jan 29, 2005 at 15:41
http://www.bbc.co.uk/topgear/prog28/hilux_broadband.ram
That one was an absolute cracker.
Im still waiting on a follow up one for a Nissan. Something tells me it wouldnt last more than 2 tests.
go yota!
FollowupID: 354275
Follow Up By: Bonz (Vic) - Saturday, Jan 29, 2005 at 17:04
Looks like Johnno's back
FollowupID: 354287
Reply By: Member - Bradley- Wednesday, Jan 19, 2005 at 12:07
was he carrying anything fairly heavy in the back of the tub ? fairly common for them to move around lots when loaded, so he may have just bent the mounts. Ditto - find it hard to believe bending the chassis. ( i have seen what our little hilux has carried in its time - 1200kg+ - and no dramas there )
AnswerID: 93909
Reply By: locallaw - Wednesday, Jan 19, 2005 at 13:34
Gidday,On a trip to the Cape I have come across 2 Hi-Luxes with bent chassis.They were bent at the front of the rear spring hangers.At the time they looked hilarious with the headlights pointing down and the tray pointing up at the sky.They were straightened ,gusseted and they went on their way.I expect it cost a small fortune to repair,but they do bend.I might add both these utes were well loaded.
Seeya Locallaw
AnswerID: 93919
Reply By: Alan S (WA) - Wednesday, Jan 19, 2005 at 15:16
I would not have thought towing would have any effect as the towbar forces are backwards from the Chassis, and the tub sits on the chassis. Unless the towbar was fitted directly to the tub there should be any towing forces on it.
AnswerID: 93936
Follow Up By: Mad Dog (Victoria) - Wednesday, Jan 19, 2005 at 16:24
The up and down "pitching" forces are HUGE Alan. That's why manufacturers put ball weight limits on their vehicles
FollowupID: 352907
Reply By: Bob Y. - Qld - Wednesday, Jan 19, 2005 at 16:12
Eric,
Had a leased hilux d/cab last year that we cancelled the lease on. Had sent one of the young blokes out to tow a fuel tanker up to another job. Didn't think of tow ball weight at the time, but the hilux ended up with a bent chassis. This young bloke was suspected of being a lead foot, and his interpretation of "taking it steady", was probably a lot different to ours.
We drove it for about 12months with bent chassis, and only thing that appeared to improve things, was when it driven over tight creeks, and the rear of chassis slammed down on creek bank. Did straighten a liitle.
Ray's tale of the pommy hilux, certainly wouldn't be one of the later IFS models!!! They're not made for the "great outback" anymore.
Hooroo...
AnswerID: 93948
