Question re Spot Light globe in my IPF's
Submitted: Wednesday, Jan 19, 2005 at 23:27
ThreadID: 19598 Views:4703 Replies:4 FollowUps:3
I noticed one of my spotties going dull over a period of time and pulled the globe out today for a look.
It's a standard IPF 12v 100watt globe. I noticed it had discoloured badly and the globe was a dark grey colour. The metal was obviously heat damaged and had gone purple. The globe still worked but was very dull.
I've replaced it now but does anyone know why this would happen? The other spottie globe is fine and I've had them since new in June 2002.
If your wondering, I haven't touched the globe at any time. I know you're not meant to.
Cheers crew
Reply By: Member - Ed. C.- Thursday, Jan 20, 2005 at 00:33
G'day Andrew,
I've had the exact same thing happen from time to time, & never really thought much about it.. just put it down to the globe(s) "dying a natural death"...
It'd be different of course, if this were happening on a regular basis, but after almost 3 yrs, I don't think I'd be too concerned about it... (presumably, the lights have had some "regular use" in that time??)...
Some brands of globe may be more (or less) susceptible than others, but as I said, if it happens only occasionally, I just shrug my shoulders & replace the globe (checking the connections while I do so;-))...
I was told many yrs ago by a (then) auto-leccy that halogen globes have a finite "switch life".. i.e. the more you switch them on & off, the sooner they will "die".. conversely, if switched on & left on (& not subject to vibration), the globe could well last indifinitely.. I have no idea of the veracity of that statement, but the bloke who told it to me was (at the time) a practising auto-electrician, so I accepted it as fact...
Regards, Ed. C.
Confucius say.....
AnswerID: 94010
Follow Up By: Member - Andrew(WA) - Thursday, Jan 20, 2005 at 02:20
Thanks Ed
From what you and Muz tell me it seems normal. I was worried it may be a glitch in electrics but i'm happy now.
FollowupID: 352969
Reply By: Member - muzzgit - Thursday, Jan 20, 2005 at 01:48
Andrew. What is said above is spot on.
BTW, Don't be tricked into getting 120 watt globes for replacements, they burn out real quick. Getting off the subject a bit.......
I tried a set of philips +50% globes in my cibie oscars a while back. I was told they are brighter than 100 watt, although they were only 50 watt, but that new
you-beaut "white/blue" type of globe.
What rubbish.... they were really bright white/blue alright, but were at least 30foot shorter in light throw from the car than the original 100 watters.
(doh. sucked in again !).
I gave them to a mate who put them in the high beam of his 80 series and, they rock !! he loves 'em. Thats because the globes he took out were 65 watt and these are 50watt but 50% brighter (go figure !)
I'm gonna try the same globe in H4 high/low in the patrol, apparently thay make quite a difference.
AnswerID: 94016
Follow Up By: Member - Andrew(WA) - Thursday, Jan 20, 2005 at 02:18
Thanks Muz
The H4 in the high/low your talking about....is that the normal headlights your refering to?
If so, I'd be interested to hear what you know. I take it the standard globe is H3 55Watt???
What will you be putting in to replace it?
FollowupID: 352968
Follow Up By: Well 55 - Thursday, Jan 20, 2005 at 13:33
Have put the Vision + in my GU, they are 60/55w. Heaps brighter and I think a better output. They claim 10-20m longer beam and thats about right. They fill the gaps on the side of the road a lot better.
I'm on a narrow road and the last 7k dirt and this is where the lights are heaps better. Only use the spots for long distance on the open roads.
FollowupID: 353067
Reply By: muzzimbidgie - Thursday, Jan 20, 2005 at 18:39
Hi Andrew. The globes for a single light are H3. eg; spots, or high beam on a twin headlight setup like the 80 series cruisers. My GU patrol headlights run H4 globes which are 60/55 watt.
I've gone back to the normal 100 watt globes for my cibie oscars, which aren't terribly good lights compaired to what I've had in the past! If i'm a good boy this year I might talk santa into getting me some 170 lightforce. te he
P.S. is doesn't hirt to check the electricals anyway. Put ur high beam on with spotties on (motor running) and give everything a good wriggle and check for corrosion in all joins and connections. Usually a faulty earth is to blame for trouble with lights. Also, when replacing a bulb in a spottie, probably a good time to open the other one up and have a peekaboo for corrosion.
Muzz
AnswerID: 94136
Reply By: Member - Matt Mu (Perth-WA) - Friday, Jan 21, 2005 at 13:47
Andrew from what I was taught years ago, the Halogen globes are filled with an inert gas that is present to stop the filament burning out when the current is applied. ie they will glow (give off light) but not just fizz like a fuse.
Over time the gas does break down or change slightly so that the filament will start to burn and in an old globe this discolouration is the the burning. It will continue until the light blows, then you usually notice the globe is all black inside from the final fizz.
So I guess ou just have caught your globe in a very controlled state of burning out and if left I presume it would blow soon.
The challenge for the manufacturer is to find a gas that doesnt brake down and still gives off a fantastic light, ie Xenon mixes being used now in more expensive globes.
I spose soon all cars will be manufactured with the HID lighting systems and that will be the end of Quartz Halogen.
Hope that helped!
Matt.
Matt.
AnswerID: 94264
