Name Search in Ozziexplorer
Submitted: Monday, Jan 24, 2005 at 22:18
ThreadID: 19742 Views:2731 Replies:3 FollowUps:3
I have Nat Map Raster 2003, how do you do a name search while viewing the maps in ozzie. It works fine in the Natmap Viewer but nothing in ozzie.
Do I have to get hold of the name files from somewhere?
Fridge Update
Tried lighting it on gas the other it wouldnt light. Got the gas bottle filled just in case, still wouldn't light. Aggggggghhhhhhhh.
Found a place up Tweed that sevices them, thats my next stop, after the new canvas.
Suppose to be ready by the 8th Feb, the canvas gets done on the 2nd 3rd 4th. Will be cutting it fine. So much fun. Now we have a noise that seems to be coming from the alternator. Never endinggggggggggggggg.
Reply By: David Au - Monday, Jan 24, 2005 at 22:28
This website will answer your prayers
http://members.optusnet.com.au/%7Elink_jt_1/namesearch.html
AnswerID: 94741
Follow Up By: Member - Craig M (NSW) - Monday, Jan 24, 2005 at 22:46
Hi David,
Thanks for the reply.
I have been to that sight already, I downloaded a few of the name files and the name search program. And the only one I cant get to work is the Natmap Raster names file. Once you unzip it using the name seach prgram and try importing it into ozzie it comes up blank.
Even the downnload is small only 23kb.
Any ideas?
Imust be doing something wrong.
Its funny though the other name files work fine.
FollowupID: 353619
Reply By: Outnabout David (SA) - Tuesday, Jan 25, 2005 at 09:36
Craig,
Have you set ozzie up to search the correct file path? I think my name file is in a separate directory to the maps and data files and this needds to be set so it searches the right directory I think.
AnswerID: 94784
Follow Up By: Member - Craig M (NSW) - Tuesday, Jan 25, 2005 at 22:26
Hi david,
I will check out the name files, as when I copied the maps across to the hard drive I am pretty sure I just took everything.
But will make sure. And check where it goes looking.
FollowupID: 353770
Reply By: signman - Tuesday, Jan 25, 2005 at 12:11
G'day Craig
Have you downloaded and updated the Raster .map patch update? I found my OxiExplorer wouldn't work with the Raster map till I installed the update??
There should be no need for a name search modification.
Any probs, give me a reply.
regards
Signman
AnswerID: 94807
Follow Up By: Member - Craig M (NSW) - Tuesday, Jan 25, 2005 at 22:28
The map part works fine, you can look around on the map okay just cant do a name search. Where do you get the map patch from?
Looked on the Govenrment Raster site but couldn't find anything. I am just going to go and check out the Ozzie site. Am I getting warm?
FollowupID: 353771
