Increase wheel size
Submitted: Monday, Jan 24, 2005 at 22:34
Member - John M (WA)
I thinking (what a noise) about increasing my wheel size from 15x6.5 to 16x7 rims
to match the size on my campertrailer My vechile is 1991 Toyota Hilux Surf(imported) Auto 2.4l turbo desiel was wondering if there would be enough power to drive the extra size of wheel will be fitted with BFG 694 tyres. Any info would be appreciated Regards John M (WA)
Reply By: Member - Blue (VIC) - Tuesday, Jan 25, 2005 at 00:19
If you keep the tyre diameter the same, it won't make a difference... If you are going to 31x10.5's, you may have issues with legallity/roadworthyness/insurance.
94761
Follow Up By: Member - John M (WA) - Tuesday, Jan 25, 2005 at 15:53
G'Day Blue,
I had the legallity/roadworthyness covered but had not thought about the insurance Many Thanks for
the tip John
353706
Reply By: Member - Roachie (SA) - Tuesday, Jan 25, 2005 at 08:03
G'day John,
Bearing in mind that similar overall-sized tyres (say 31" diameter) to suit 15" rims are quite a bit cheaper than the equivalent 16" rim sized tyre.
If I was in your shoes, I'd be more inclined to change the rim size on the camper trailer down to 15" to match the vehicle....also it would mean having to only buy 2 or 3
wheels & tyres instead of 5.
94771
Follow Up By: Member - John M (WA) - Tuesday, Jan 25, 2005 at 16:12
Hi Roachie,
After reading your reply, I did not think of your suggestion (probally due to the noise of thinking) but I would still like to go to a 7" wide rim on the vehicle which I can pick-up for about $40 - $50 ea, I have done some calculations and your suggestion plus 7" rims all round works quite a bit cheaper than and I even get an allowance for the other rims and tyres.Thanks for the suggestion will keep you informed how it works out.
Regaeds John
353709
