ABS or not
Submitted: Sunday, Feb 06, 2005 at 10:17
ThreadID: 20168 Views:2517 Replies:5 FollowUps:4
Currently have a DX patrol.........looking to upgrade to a ST-S which has ABS, Is it a $2000 option well spent as I've never driven a car with ABS?
Paul
Reply By: Rob from Cairns Offroad Training & Tours - Sunday, Feb 06, 2005 at 10:39
I thought ABS was standard on the model, an expensive option at $2000 I would not bother. If you learn correct threshold braking technique you will out brake ABS on dirt roads anyway. Cheers Rob
AnswerID: 96916
Follow Up By: Paul - Sunday, Feb 06, 2005 at 10:46
Rob,
sorry, yes its standard on the ST-S , ST it is not and the price difference between the ST and ST-S is approx $2000.
For that $2000 you also get set tray on the back of the driver and passanger seats and different material on the seats.....whoppe !!!
thus i'm swaying between ST and ST-S
Paul
FollowupID: 355538
Reply By: brian - Sunday, Feb 06, 2005 at 10:43
abs great on bitumen but can be nightmare on dirt especially when towing so much i sold my patrol with abs and repurchased patrol without abs.didnt know you could disable abs by removing fuse,some people on this site have installed a switch in their vehicles to turn off abs as desired.
AnswerID: 96917
Reply By: brian - Sunday, Feb 06, 2005 at 10:52
off the topic but does this model have 17 inch rims,very limited tyre choices and virtually no 17 inch replacements away from cities
AnswerID: 96918
Follow Up By: Paul - Sunday, Feb 06, 2005 at 10:57
It does, but I read somewhere that there was plenty of options for 17" rubber, my camper trailer has 16" , Nissan tell me the stud pattern is the same as the 16"......i'll start anoth thread on this.
Paul
FollowupID: 355540
Follow Up By: Paul - Sunday, Feb 06, 2005 at 12:57
Found the reference.....
Feb 05 Overlander 4WD Mag
In the Patrol section of the 4WDOTY....Practicalites
"The ST comes with 17" wheels, unlike the base specs models which retain 16". Either way, thers more choice with 17" rubber these days......"
So there you have it...if you beileve them there is a better choice with 17" rims.
Paul
FollowupID: 355553
Follow Up By: Patrolman Pat - Sunday, Feb 06, 2005 at 13:56
"Either way, thers more choice with 17" rubber these days......"
So there you have it...if you beileve them there is a better choice with 17" rims. "
I read that as meaning there is more choice in 17" tyres than there used to be, emphasis on the THESE DAYS; not more choice over 16" tyres.
FollowupID: 355558
Reply By: Member - Jeff M (WA) - Sunday, Feb 06, 2005 at 11:48
The effectivness of ABS can vary quite dramatically from car to car. I've never driven a patrol with ABS on dirt but I have driven a number of vehicles with ABS and had to use it. (I do about 1000ks a week).
My expereinces on road with ABS are nothing but supurb. In fact if I was buying a family sedan or wagon I would never skimp on paying the extra for ABS. It's truley a life saver. (yes threshold braking works, but there are somtimes other facters. eg braking while turning on uneven surface while hitting some oil etc etc etc). It only takes a second of wheel lock up to loose your steering at the most important time and hit somthing or someone.
My experiences on Dirt roads and in Mud have been quite scarey. Strangley Enough I found the BA Falcon's ABS better in Mud than the Subaru Forrester! ?? work that one out!? (Mind you it was the only thing I could find that I would call good from the BA) LOL
I've also driven a GU in the wet and had to stop in a hurry. The thing locked up faster than I could poke my toung out and it was like watching a kid on a slippery dip.
Considering the majority of most people's drivig is done on road I'd pay the extra if I had the option of disabling it.
AnswerID: 96925
Reply By: Member - Captain (WA) - Sunday, Feb 06, 2005 at 18:46
Hi Paul,
I have a GU ST and went the option of the safety pak (now the ST-S model). IMHO ABS brakes should be mandatory on every new vehicle these days. They are such a life saver on-road that it should be thought of just like seat belts. Unlike airbags, which only help you in a collision, ABS may prevent a collision in the first place.
My wifes vehicle is a people mover and ABS has saved her and my 2 kids in a freeway incident. A vehicle slightly in front of her crashed into the guard rail and richoceted into her lane at 100 km/hr. She hit the brakes hard and managed to steer into the next lane. Without ABS she would have skidded straight into the vehicle. So what could have been a tragedy was simply a near miss. While she also had airbags which "may" have saved her, the ABS prevented the collision in the first place.
I have used my ABS on gravel and I reckon it stops as quick, if not quicker, than I can without it! It has a very long "on" cycle and is supposedly tuned for gravel roads by swapping to a different progam (not sure how, maybe by deceleration rate). Bottom line is, I actually now prefer it on gravel. Others have a different opinion, but they may have the earlier model ABS with different programming.
While I bought my vehicles, I got ABS for the type of reason my wife experienced, the fact this happened has confirmed my opinion that ABS should be mandatory. Even if they do compromise offroad performance, that is such a small price to pay.
While you may think you can use threshold braking (I have been to Driver training courses and practised it), in a real incident it would be hard to actually use. Also, do you think your wife would be able to use threshold braking in an incident? There will be times when you are not the driver and a less expereinced person will be at the wheel.
Anyway, I'll get off my soapbox now, but I do hope you seriously think about getting ABS.
Captain
AnswerID: 96968
