Circular water tank in spare wheel cavity
Submitted: Sunday, Feb 13, 2005 at 08:37
Member - Chrispy (NSW)
Hi all
Has anyone ever heard of any manufacturer making circular
water tanks that fit into the spare wheel cavity under the rear floor (of any type of vehicle that used to store the spare there)? I'm moving my spare out to a rear carrier, leaving a lovely hole under the floor that will take a 31" tyre. The reason I'm moving it is because I have a set of roller drawers (hinged at the front) that sit in the back making access to the spare a right-royal PITA. I'm guestimating that there is around 35-40 litres-worth of
tank - if not more - that I could build in to that space.
Anyone ever done it on their vehicles?
Chris
Reply By: Savvas - Sunday, Feb 13, 2005 at 08:55
I haven't heard of one, but what a great idea!
98098
Follow Up By: Member - Chrispy (NSW) - Sunday, Feb 13, 2005 at 09:07
hehe..thanks Savvas :)
Yeah...after moving to the Jeep - it's a fair bit smaller than our GQ, so any better use of space is always a consideration. I was thinking of putting a diesel
tank there, but I'll be putting that underneath along the LHS chassis rail (even though it's monocoque - it has some beefy rails still). So...
water it is. Just a question now of how to plumb filler and outlet hoses through the walls of the cavity...
356626
Reply By: Lone Wolf - Sunday, Feb 13, 2005 at 09:29
I second Savvas's opinion.....
Top idea!!
What about a bladder?
Wolfie
98104
Reply By: Andrew from TrekTable - Sunday, Feb 13, 2005 at 09:30
Chrispy,
I don't know of anyone making a specific
tank for the purpose but I would suggest you could use a normal bladder
tank. You can buy them quite cheap from marine chandleries. I think I paid about $80 for my 100litre
tank. They are flexible and tough so they mould to almost any shape and would be very good for what you want. You could drop an outlet pipe thru your floor to achieve a gravity discharge.
Just a thought.
andrew
98105
Follow Up By: Member - Chrispy (NSW) - Sunday, Feb 13, 2005 at 10:06
Thanks Andrew - Do you know the approximate dimensions of your 100L bladder?
356631
Follow Up By: Andrew from TrekTable - Wednesday, Feb 16, 2005 at 21:54
Chrispy,
Apologies for the delay. I've been away.
I don't actually have my 100 litre bladder
tank anymore because I sold it with my last boat. But from memory it was about 0.8m x 0.4 x0.2 (I think).
If you pop into a nearby chandlery, you'll be able to measure one no probs.
357140
Reply By: Member - David C (QLD) - Sunday, Feb 13, 2005 at 09:35
It is a great idea. In the case of a 31x10.5 tyre, you get 129.87 useable litres of space (pie x r² x h). That makes for a very useful
water tank (albeit a heavy one).
David
98107
Follow Up By: Lone Wolf - Sunday, Feb 13, 2005 at 09:43
Someone's been using a calculator!!!!!!
356628
Follow Up By: Member - Chrispy (NSW) - Sunday, Feb 13, 2005 at 10:01
Thanks David
Yup - I get about the same figure doing the PiR squared by depth calculation too. There are a few protrusions (small hub in the centre of the cavity which houses the tie-down for the spare, but that's about it. I reckon around 65-80 litres would be sufficient. I want to go with a stainless
tank taher than a bladder. Although the bladders do conform to irregular shapes, I'm just afraid of constant rubbing and chafing of a bladder
tank while it's under the drawers - so it would never see the light of day for periodic inspection. At least with stainless - I'd be happy to leave it alone for years.
I'm definitely going to investigate further - and if no manufacturer has already thought of this idea, I'll whip up to Out of Town 4WD in the
Newcastle area who manufacture from scratch. They're currently developing (this week!!) a long range
tank for the Grand Cherokee CRD anyway - so this might be a good project for them too.
356629
Follow Up By: Lone Wolf - Sunday, Feb 13, 2005 at 12:34
"you get 129.87 useable litres of space (pie x r² x h"
I am having some problems with this. The mensuration seems a little wrong.
Think of it this way............
60 - 70 litre petrol
tank........... with a 127 litre recess...............
Wolfie
356635
Follow Up By: Lone Wolf - Sunday, Feb 13, 2005 at 12:53
Well, I did the math, and you guys are right. Perhaps the fuel
tank is like the Tardis!!
I just look at a 44 gallon drum, and think....... 200 litres........
I look at a wheel & tyre, and think........... maybe 40! I was wrong!!
I'm goin' back to school.......... with my slide rule!!
Wolfie
356636
Follow Up By: Member - Chrispy (NSW) - Sunday, Feb 13, 2005 at 12:58
Actually - it's less.
31" wheel x 10" depth = 78cm diameter x 25.4 deep.
Radius = 1/2 dia, so we say 39cm radius.
Pi R squared = 3.141 x 1,521 (39 squared) = 4,777
multiply by depth (25.4) = 121,347 cm2 or 121 litres.
Given that there would be gaps down the sides and because of
the hump in the middle of the
well, lets losw 30 liters. We still wind up with 90 litres of usable volume.
Looks good to me ...... :)
356637
Follow Up By: Member - Chrispy (NSW) - Sunday, Feb 13, 2005 at 12:59
(typo - cm3 not cm2)
356638
Reply By: Ray Bates - Sunday, Feb 13, 2005 at 09:54
Hi Why not use a modified inner tube?
98109
Follow Up By: Member - Chrispy (NSW) - Sunday, Feb 13, 2005 at 10:04
Ray - don't inner tubes have a dust-coated interior? I think they dist it so that the inner walls don't stick together. It might be alright for washing
water, but I'm not sure that I'd want to drink from it.
The shape would be right though! :)
356630
Reply By: udm - Sunday, Feb 13, 2005 at 10:09
I´ve seen somebody making some kind of
tank, can´t recall if it was a
water or lpg
tank.
98110
Reply By: Coops (Ex-Pilbara) - Sunday, Feb 13, 2005 at 10:36
what a superb idea.
I'd patent that one if it's not already taken
98114
Reply By: Member - Chrispy (NSW) - Sunday, Feb 13, 2005 at 11:03
Thanks everyone :)
The other reason why I was thinking stainless was that if I wanted to mount the filler and outlet on the rear face of the drawer system (inside the car) then I could pressurise the
tank a little with the on-board compressor and be able to flow the
water upwards and out the back of the drawers against gravity. It would be a very neat installation I think.
98116
Follow Up By: Puddin & Gumnut (Sydney) - Sunday, Feb 13, 2005 at 17:24
ring some stainless steel manufactures & ask them but I don't think it will be cheap or easy to make as it's round. you could use a shure flow pump to suck it out if you can get it made. If you live in
Sydney there is a stainless guy behind TJM @ Blacktown.
356653
