Fridge/auto electric repairs
Submitted: Monday, Apr 30, 2001 at 00:00
ThreadID: 204 Views:2920 Replies:3 FollowUps:1
Fridge keeps blowing fuses and I need someone who will look at car and fridge as one system. Fridge repairer says fridge is OK. Auto electrician says wiring is OK but neither can check others work. Tired of paying out money for no solution. Anyone remotely near Kirribilli would do.
Reply By: stephen mills - Saturday, May 05, 2001 at 00:00
Try Con at Electromotive 198 Princes Highway arncliffe, phone number eludes me but in the book. This man is an electrical wizard on cars and comes highly recommended!! If the fridge is the problem that may be another issue but bring it out for him to look at and advise!
stevebalmoral sydney
AnswerID: 426
Reply By: Jim Robinson - Saturday, Jun 02, 2001 at 00:00
What type of fridge?
What size fuse?
AnswerID: 585
Follow Up By: Robert - Monday, Jun 04, 2001 at 00:00
Medium size Engel. Can come back with model number. Fuse was 15 amp although one expert(?) suggested 25amp which had a similar life. ie. dont blow instantaneously but after about 1/2 hour of use.
FollowupID: 155
Reply By: Dion Chandler - Tuesday, Jun 12, 2001 at 00:00
A medium size Engel should run happily on a 10 Amp fuse, my 29L does. Only if I also put my 15L Engel on as well do I replace both 10Amp fuses with a pair of 15Amp fuses. When no longer immediately required to run both fridges, back the pair of 10Amps go. Cheers, Dion.
AnswerID: 626
