Waeco 35
Submitted: Wednesday, Feb 16, 2005 at 08:16
ThreadID: 20498 Views:1914 Replies:4 FollowUps:2
Hi Folks
On the Waeco 35 there is a switch that is labeled, low - off - high. What are the low and high settings for
Thanks Ray
Reply By: Lone Wolf - Wednesday, Feb 16, 2005 at 08:24
From memory, it is the residual voltage cut off detector.
If your car battery gets too low, the fridge will turn off.
High = let's say 11 volts or something, can't remember.
Low = let's say 9.5 volts or something.....
Off = will run regardless of battery voltage.
Wolfie
AnswerID: 98615
Follow Up By: Vince NSW - Wednesday, Feb 16, 2005 at 09:29
Amost spot on Wolfie.
I have just found the instructions from mine.
"High" cut out at 11.5 v
low" cut out at 10 v
"off " (must be irish) means it's on down to the last little volt
Vince
FollowupID: 357028
Follow Up By: scott111 - Wednesday, Feb 16, 2005 at 14:41
On my ccf-35 "off means off no power to fridge"
FollowupID: 357073
Reply By: tessa_51 - Wednesday, Feb 16, 2005 at 10:47
"off" - must be made by microsoft
Tessa
AnswerID: 98635
Reply By: Kiwi Ray - Wednesday, Feb 16, 2005 at 14:07
Thanks for that info that helps a lot, the booklet that came with the fridge was not very clear as to what the switch does
Ray
AnswerID: 98669
Reply By: MRTEE ( VIC ) - Wednesday, Feb 16, 2005 at 20:08
Hi Ray I have the same fridge high is for single battery, and low is used for duel batterys o is for duel as well, but will run the fridge untill the battery is completly flat they are a great fridge.
AnswerID: 98723
