OziExplorer ?
Submitted: Sunday, Feb 20, 2005 at 15:38
ThreadID: 20605 Views:2678 Replies:3 FollowUps:11
Hi all
When ever i try to import a OziExplorer Track Point File Version 2.0
WGS 84
Altitude is in Feet
Reserved 3
0,2,255,OziCE Track Log File,1
-31.9632367, 115.9437717,0, 124.7,38205.9417593 ,060804,223622
for example, there is nothing to see there is a file to save but when I do, it will not open.
I don't do this that often but yesterday someone had a link to Lcool and i was reading there notes on the double Simpson crossing, i tried to copy and paste the track so I could see were they traveled while reading, then spend the rest of the trying to get them to work. (another hard day at home).
If anyone can it will be much appreciated
Richard
ps. I have tried saving my plt file as text and importing them still no workers
Reply By: Mad Dog (Victoria) - Sunday, Feb 20, 2005 at 17:11
Richard, I just loaded a .plt file, exported it as a .txt file and then imported it all ok. I don't usually do this either.
Assuming you are using import and export for the .txt file and not load and save there can only be something wrong with the format of the .txt file you are trying to import.
This is the format of the .txt file that worked for me.
Datum,Australian Geodetic 1966
TP,D, -37.100203, 143.365693,08/03/2003,01:12:23.000,1,-9999,1, , , ,
TP,D, -37.100193, 143.365625,08/03/2003,01:15:54.999,0,-9999,1,6.1,212.0,0.03,280.4
TP,D, -37.100206, 143.365677,08/03/2003,01:27:22.000,0,-9999,1,4.8,687.0,0.01,107.3
TP,D, -37.100230, 143.365617,08/03/2003,01:33:57.997,0,-9999,1,6.0,396.0,0.02,243.5
TP,D, -37.100418, 143.365617,08/03/2003,01:34:04.002,0,-9999,1,20.9,6.0,3.47,180.0
TP,D, -37.100648, 143.365652,08/03/2003,01:34:09.998,0,-9999,1,25.7,6.0,4.29,173.1
AnswerID: 99163
Follow Up By: Richard Kovac - Sunday, Feb 20, 2005 at 18:08
Thanks Ray
I tried your way and it works OK
I see what some people mite be doing.
That is opening the plt file as text files then copy & pasting or saving them as text files
Which is the wrong format for Ozie
it was worth a try
Richard
FollowupID: 357500
Follow Up By: The Explorer - Sunday, Feb 20, 2005 at 18:33
Richard...So the problem was that you were trying to import it as a text file? The data you entered above opens ok when saved in notepad as a *.plt file as ..
WGS 84
Altitude is in Feet
Reserved 3
FollowupID: 357502
Follow Up By: Mad Dog (Victoria) - Sunday, Feb 20, 2005 at 18:41
hehe..was just going to say change the extension to .plt but Greg got in first.
FollowupID: 357503
Follow Up By: Richard Kovac - Sunday, Feb 20, 2005 at 20:01
Ray
I maybe dumb but how do you save the ext on the file in note book or word?
Richard
FollowupID: 357507
Follow Up By: Richard Kovac - Sunday, Feb 20, 2005 at 20:20
Ray
How did you download it save as / copy and paste
i can do both but can't see them
running ver 3.95.4g
must have some settings wrong
I have found a work a round anyway
I imported the file exported as a text file and when I re import it i can see it
Richard
FollowupID: 357509
Follow Up By: Mad Dog (Victoria) - Sunday, Feb 20, 2005 at 20:26
file/save as
a box will pop up where you can specify where you want it saved to along with a name and extension of your choice
or....right click on the file in windows explorer and hit rename, give it any name you like with a .plt extension
FollowupID: 357511
Follow Up By: Mad Dog (Victoria) - Sunday, Feb 20, 2005 at 20:32
I downloaded it as a file straight to the disk Richard....day1.plt
it opened up in ozi ok......from Birdsville across Big Red and about 50K's along the QAA line
FollowupID: 357513
Follow Up By: Richard Kovac - Sunday, Feb 20, 2005 at 20:34
Thanks Ray
I'm now not as dumb as I think lol
forgot to hit ALL FILES
Richard
FollowupID: 357516
Follow Up By: Mad Dog (Victoria) - Sunday, Feb 20, 2005 at 20:38
arhhh, another mystery solved.....good luck
FollowupID: 357518
Reply By: Richard Kovac - Sunday, Feb 20, 2005 at 19:17
No what I was trying to do was copy the file on the link and open it on Ozie
lcool
Hope this works
Richard
AnswerID: 99191
Follow Up By: Mad Dog (Victoria) - Sunday, Feb 20, 2005 at 19:40
You've confused me Richard. I downloaded the file and it opens in Ozi just fine.
FollowupID: 357506
Reply By: Michael Carey - Monday, Feb 21, 2005 at 07:54
Hi Everybody,
Loading the above .PLT file into my Oziexplorer has shown me a problem I haven't come across before!
I have several types of maps, HEMA GDT, 1:250000, 1:50000 of South OZ, NASA sat images. I tried to do a track replay using the "day1.plt" and all I got was a rapid loading of first the 1:250000 Birdsville map and then the 1:250000 Betoota map and then back again. Upon checking the calibration points, I found the the Birdsville map points are quite a ways in from the edge of the map, in fact Birdsville is in "No Mans Land" where going by calibration points, it's not on either map, hence the rapid swapping of maps in track replay!
I am going to have to re-do the points so that the points are closer to the edge of the map and check out some more maps to see how common this will be.
Just a FYI!
Regards,
Michael.
AnswerID: 99273
Follow Up By: Richard Kovac - Saturday, Feb 26, 2005 at 23:24
Michael
Try down loading the lates map files from ozie.com
the new maps have been re- calibrated
regards
Richard
FollowupID: 358494
