?TJM or ARB Suspension lift
Submitted: Tuesday, Feb 22, 2005 at 20:23
skip
Can anyone offer there 1st hand experience with either product TJM or ARB
vechile current V6 prado required a little lift due to lack of clearance not as the 90series went further with out hitting its belly ? what has anyone found with each product built better,value reliable etc. Thanks Skip
Reply By: MAVERICK(WA) - Tuesday, Feb 22, 2005 at 20:40
Here goes - set of OME H/D springs for 130,000kms - good when towing and loaded - bit rough when unladen - approx 75mm lift - Series 2000 shocks at the same time - good and heavy and did not seem to mind the corrugations (living in
Broome during most of this time). Replaced the whole lot 6mths ago and now have series 2000 H/D springs - better ride unladen and seems ok when loaded (no longer towing and no more kids so the vehicle is carrying less anyway) - 75mm lift - OME shocks - again don't seem to fade when on the corrugations and are handling everything else
well. The ride seems a bit more comfortable (compliant) now. Why the mixing of brands - $$$$$$$ - got a good price on the Series 2000 springs 6mths ago - got a great price on the shocks from ARB (threw in a steering damper). 10yrs ago got a great price on the OME springs freighted up from
Perth and a good price on the Series 2000 shocks. What does it all mean - not much I guess only that they appear to work for my vehicle (LWB Maverick) and haven't stuffed up - satisfied with the outlay and return - what more can you want???? rgds
99548
Reply By: GazzaS (VIC) - Tuesday, Feb 22, 2005 at 21:38
Hello Skip
sorry - cannot offer any experience of these products. Have been doing my own research on this site plus a couple of specific Prado forums. I have a 90 series and have opted for a different brand of coils (to the 2 you mention) plus airbags for the big loads. I have found for the 90 at least a lot of people have said no need to replace the dampers (shocks) as they are OK standard as long as the spring lift does not exceed 50mm. This has been confirmed by a number of spring suppliers other than those specialising in the full kit. I guess I will know in a couple of weeks when
mine are all fitted.
If you want to look at the Prado specific sites take a look at
www.lcool.org
http://groups.yahoo.com/group/90series
you might need to
sign up - cannot remember - but cost nothing and like this
forum heaps of knowledge "on tap".
Gazza
99570
Reply By: DeanoNSW - Wednesday, Feb 23, 2005 at 03:06
Not sure with respect to the Prado, but I went down this path a few months back with my GU patrol I ended up going with neither and I know that I got a better deal.
ARB and TJM can be quite expensive for what you get in my opinion. For the price of a complete set of OME basic kit (springs and shocks - nothing else) I got the top of the range Koni shocks (which can be re-built when they wear out) and lovell springs. I can adjust the shocks to suit conditions (requires a bit of stuffing around). I am thoroughly happy with the ride - both laiden and clean.
My advice is go to a
suspension specialist and your dollar will definately go further. ARB and TJM will try and run the arguement that they have stores nationally and support their product better.
Well Lovell springs and Koni shocks have dealers throughout the country (Same for King Springs.) and they have been doing springs and
suspension for years and years.
On a side issue, I wouldn't be going above 50 mm or you will find your insurance premium will be very expensive, and many insurers will not want to know you.
regards
Deano
99619
Reply By: Wayne (NSW) - Wednesday, Feb 23, 2005 at 06:36
Skip,
The springs are not a big issue, ARB and TJM are King Springs in a diffrent box. Lovelles spring are also fine for the Prado.
What I have found is the shocks make all the difference. Either Koni or Bilstens. They are a bit dearer but because of the set up of the vehicle they seem to work the best.
Keep the lift to a max of 50mm. Front end and insurance problems might accure if you go any higher
Wayne
99624
Follow Up By: Crackles - Wednesday, Feb 23, 2005 at 18:01
Got to agree Wayne. The Koni's have the name for reliability & Bilsteins the reputation for performance. The Lovells springs work
well too.
Cheers Craig.....
HZJ105 Koni's on Lovells, 150,000KM+
358037
Reply By: GO_OFFROAD - Wednesday, Feb 23, 2005 at 07:22
We do 40mm / 60mm / 80mm lifts for prado, using the correct % rate spring for your requirements, and matched to the shock valving.
We use Bilstien shocks, velocity controlled valving, and the front struts have 3 seperate height settings for alloy bar, alloy bar and dual batteries, steel bar and winch with dual batteries.
We use all toyota bushes all around, as they last better than the aftermarket versions.
If you try the 90 list on www.lcool.org or the 120 list, there are 10 or more people on there who have our package, and more than 50% have replaced OME with our package, for the improved ride, handling.
Ivan, who is on here, and lcool.org had our package fitted to his vehicle, removing the OME, after riding in my vehicle [90 series] on my xmas trip.
99629
Follow Up By: GO_OFFROAD - Wednesday, Feb 23, 2005 at 07:24
forgot to add, we can freight to anywhere
and you can contact me by phone 0352216599 [bus hours]
or email
darrenm@bigpond.net.au
357935
Reply By: Member - Ivan (ACT) - Wednesday, Feb 23, 2005 at 08:45
I had OME heavy duty (incl 2" lift) fitted by ARB to my 90 series last year. After a
Simpson Desert trip (and during) I was suffering from bump stop familiarity, and sag when loaded.
I took it back a couple of times - they just pumped the tyres up harder and said it was fine. Sag was 'within spec' - and if I wanted the shocks tested, they would have to come off, and be sent to
Melbourne to go on a machine - which I would pay for if they were 'within spec'.
I now have Bilsteins on Lovell's and even when loaded can drive straight through 'the bumps' and she soaks them up beautifully.
I went to this set up after seeing GO_Offroad's setup (and his has done the same Simpson Trip, plus a sh*t load more, and still travels beautifully) - the same track which I could only do 20 kph on, he could do 50 kph on (and smoother) - I know speed isn't the only thing here, but I think it demonstrates the difference.
The OME
suspension lasted six months on my car - I think it is marketed
well ;-)
99634
Follow Up By: DeanoNSW - Wednesday, Feb 23, 2005 at 19:11
Ivan,
how much did the ARB (OME) experience end up setting you back ?
Deano
358051
Follow Up By: Member - Ivan (ACT) - Wednesday, Feb 23, 2005 at 21:04
mate, from memory, about $1200 (fitted) - Bilsteins and Lovell's was only $300 more (though that wasn't fitted)
358071
Reply By: fourstall2000 - Thursday, Feb 24, 2005 at 08:50
Canning stock route 3 yrs ago.
Koni shocks on defender-one eye broken off.
Ironman on defender-two leaking oil through glands,one seized.
ARB on Nissan-no problems and still in use.
Lovells springs and Kings are the same and much cheaper than ARB.
The above Nissan had Lovells fitted for the Canning and performed without fault.
I have also used the enforcer brand of shocks with good results.
99875
