AnswerID: 7081 Submitted: Tuesday, Oct 01, 2002 at 00:00
ExplorOz Team - Michelle
replied:
Duncan, we currently travel with same size tyre as you and have obviously been up the
Kimberley a few times. We have run vehicles with both your size tyre (80 series) and with split rims on a Troopy. It used to be that split rims were certainly more convenient in the bush but with a good set of tyrepliers changing a tubless is now far easier and quicker so there is no need to go the splits. In fact, we would recommend you concentrate on changing the alloy rims for steel and take the
tyres you currently use (plus 1-2 spares). Unless your
tyres are dangerously low on tread you shouldn't think about changing to a new set for a trip. No tyre will guarantee you a hassle free trip, but you can get your money's worth and look around for steel rims, which are significantly stronger over such stony country. Bent and cracked rims are a problem and can be the cause of flats. We actually cracked a steal rim in the
Kimberley last year after hitting a "blind" boulder at some speed. The tyre went flat, but we could drive by using a tube inside the rim. If running tubless
tyres it is always wise to carry tubes for this sort of emergency and is much lighter than additional rubber. Finding the rims is the issue - I found a full set second hand by chance at my local TyrePower, but they are apparently like Hens teeth to find so start looking now. Expect to pay $200 each, but check the price at Toyota new they're about $500 (my memory may not be 100% but I'm going back in the archives of my mind about 4mths on this fact).By the way, the wider
tyres that are standard on the cruisers now are well suited to the outback, especially over sand like the Simpson where your big ballons will roll over the dunes like a steamroller - no worries!
Reply 1 of 4
