Need help with batteries
Submitted: Tuesday, Mar 08, 2005 at 11:53
herkman
We live in country WA.
On our estate, that consists of 130 one acre blocks, we have a stand by Ford Diesel generator, which has auto start on it.
I believe that we can buy a charger 24 volt, which will moinitor the condition of the batteries, and will keep charging or topping them up, to ensure that the engine will always start.
The stand by unit is used to run the estate
water pumps, which in turn supply pressure to the fire hydrants.
Can any one steer me in the right direction
Col Tigwell
Reply By: Member - Ed. C.- Tuesday, Mar 08, 2005 at 12:30
Col,
Go to
.. www.projecta.com.au ..
and have a look at their 3-stage automatic chargers, specifically the MD241075 ... This one is 12v 15A/ 24v 7.5A, and would suit your requirements...
I'm sure there are others as
well....
Regards, Ed. C.
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
101562
Follow Up By: Steve - Tuesday, Mar 08, 2005 at 15:27
Col
Make sure you use a three stage charger. These chargers will charge and maintain your batteries without damaging the batteries. Good quality 24V chargers can cost a bit but will pay for themselves in the long run.
Hope this helps
Steve
359477
Follow Up By: Member - Jimbo (VIC) - Tuesday, Mar 08, 2005 at 17:27
Col,
I'm with Ed about contacting Projecta. I would suggest calling them and speaking to someone about technical advice, I have done so in the past and found them exremely helpful. Call Brown and
Watson (Projecta distributors) on 03 9730 6000.
Jim.
359489
