2001 Nissan Patrol engine light
Submitted: Thursday, Mar 10, 2005 at 11:48
Rod15
Hi All,
I have a 2001 Nissan Patrol wagon, 65,00km on the clock. Recently after a 4wd excursion the engine warning light appeared and I immediatley lost power. I have had the car at the local Nissan Dealer for 5 days and they have carried out all the diagnostic tests (supposedly) regarding fuel, computer and electrics and come up with nothing.
Is there anyone out there who has had this problem and had it fixed by a competent organisation, if so can you assist me with this problem ??
Rod
Reply By: Leroy - Thursday, Mar 10, 2005 at 11:52
Hmmm sounds like a possible air flow sensor problem!
Leroy
101916
Follow Up By: Member - Michael- Thursday, Mar 10, 2005 at 17:11
I remember reading a post a while ago, it may have been on another site, where it was stated that even if the airflow sensor is within the correct voltage parameters when checked it could still be faulty and the only way to check it is to swap it with one that is known to be OK.
Mike
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
359784
Reply By: Member - Roachie (SA) - Thursday, Mar 10, 2005 at 12:16
Did they change the fuel filter. I've heard people answer this by saying..."no, it was only changed 3000 klm ago, so it must be ok"....WRONG!!!
Even a new filter will be filled with crap very quickly if you've had a load of dodgy fuel.
I'm assuming it's a 3L t/d.
Roachie
101921
Reply By: Member - Scrubba (NSW) - Thursday, Mar 10, 2005 at 22:13
Hey Rod,
It happened to
mine. I drained the fuel filted and all was fine again.
Regards...
102002
Reply By: Leroy - Friday, Mar 11, 2005 at 14:42
Just wondering if you've found the problem yet Rod? Pls let us all know.
Leroy
102071
Follow Up By: Rod15 - Saturday, Mar 12, 2005 at 14:16
Yeh G'day Leroy,
Thanks for the interest.
I have done what Michael has suggested, I swapped air flow sensor's with a mate who has the 2003 model 3ltr TD, we took it for a short drive and the engine light came as usual. However when we swapped back to the original air flow sensor I used a high pressure compressor to blow out the air filter ?? It wasn't that dirty but I thought I would eliminate that aspect as
Any way, The light has not came back on since Thursday arvo, I took it out yesterday and flogged the guts out of it and "touch wood" the light hasn't come back on.
I'm taking her out for a long run today so we'll see what happens
Regards Rod from Bunbury WA
359954
Reply By: Member - Jeff M (WA) - Friday, Mar 11, 2005 at 20:15
We had the same problem with our 03' GU 3.0L at work. Nissan had it for two weeks. The ended up putting a new EGR valve, New air sensor and it seemed to solve it, it only does it every now and then now and only if you flogg it.
It was dangerous the way it was, you'd put your right boot in to get into some traffic and the bloody light would come on and you'd end up going 20km/h in front of a road train!! ARRGH!
102099
Follow Up By: Rod15 - Thursday, Mar 17, 2005 at 00:18
Hi Jeff M (WA)
Thanks mate, more follow up since last contact. The light came on again.
Have had the Patrol to
United Diesal Injections on Great Eastern Highway.
They have eliminated all the things we have discussed on this site. Next week they are going after the "Injector pump sensor" 6 hours labour to get to it, 2 hours to replace it, 6 hours to put it all back together.
Christ knows what that is going to cost !!!!
Regards,
Rod 15 (WA)
360401
