Overheating Troopy
Submitted: Monday, Mar 14, 2005 at 11:28
kriso21
Hi All,
I wrote back in October with problems of my 91 Model Troopy overheating when heavley loaded and up hills.
The troop is supburb looking rig and mechanicaly A1 except my overheating problem. She has an after market Turbo bolted on and this is what i think is causing all my problems.
After reading the respnses back in Oct we did figure that it was the Brand New Genuine Viscous Coupling fan not having enough silicon oil in it. so that solve our problem for a while anyway. Chrissy time came and towing a fully loaded Camper trailer we found that going up big hills the temp gage would go up to the red and eventually when back on a striaght go back down to half but never below that.
We are planning a trip at
easter just up to Port and my plan was to replace the radiator with a new one and when i got speaking to guy from the radiator place he seemed to think that this wont do the trick so now i'm stuck again on what to do to stop my problem. We are planning a trip around Australia at the end of the year and i figure if it is overheating on short trips what is it going to be like across the simpson and where it is 40degrees outside to start with.
I'd really appreciate your help again here and any new advice anyone can offer.
I'd like to know how ERIC was going as he said he has had exactly the same probloms so Eric if you could get in touch that would be really appreciated.
Thanks again in advance.
Kind Regards,
Kristy
Reply By: ozi explorer - Monday, Mar 14, 2005 at 12:49
I have a 75 series 92 mod diesel ute, also with an after market turbo. From what I was told the owner of it before me (Im 2nd) had the turbo fitted (Motson??) from basically new then towed a van around Oz - best thing he ever did for it as it still goes like a rocket 275k later! (Had since 115k)
Getting back to the point, it over heated on him as
well and am sure he got a bigger 3 core radiator fitted to it. Know it only overheats on long hauls up or working hard in the sand towing, as I am currently on a trip around Oz towing a CT.
My suggestion is get another opinion on the radiator.
102355
Reply By: Shane (QLD) - Monday, Mar 14, 2005 at 13:38
Is it a 2H or a 1HZ & does it have a oil cooler.
102361
Follow Up By: kriso21 - Monday, Mar 14, 2005 at 13:49
2H and no it doesn't have an oil cooler.
360106
Follow Up By: V8troopie - Monday, Mar 14, 2005 at 16:45
My 2H troopie (no turbo) also overheated when towing a heavy boat - solved that by fitting a 6.2 litre V8 diesel :-)
Anyway, the new motor still uses the old radiator, adapted for larger radiator hose fittings. They also fitted an oil cooler, perhaps the latter might be the easiest solution for you.
The oil cooler mounts vertically on the passenger side of the radiator (under the bonnet), it takes very little room and it would be easy to fit an elecric fan to it as
well if additional anti overheating insurance was desired.
Klaus
360130
Reply By: awill4x4 - Monday, Mar 14, 2005 at 14:46
Have you got an exhaust gas temperature gauge to measure the exhaust temps produced by the turbo? If not, and your exhaust temps post turbo are over 550 degrees C then this is a common problem for overheating of diesels.
Get a gauge fitted, "thermoguard " an adveriser on this site make one and then you can really start to accurately gauge what exhaust temps you really have and drive your vehicle accordingly. If your cooling system is in good condition then this is probably where you need to go next.
Regards Andrew.
102366
Reply By: banjodog - Monday, Mar 14, 2005 at 18:20
How long since the thermostat was replaced? If it's been a while replace it but consider one that opens at a lower temperature.
The
water pump impeller blades may be rusted away too - but that's the extreme. Seen some pumps that were nothing more than a disc to try and push the coolant around. It was nothing more than the coolant thermo-syphoning around the system to try and keep cool.
Don't overlook the radiator hoses - they too will collapse and restrict the coolant flow under load / heat. Hence the reason some have the wire spring in them to prevent this from happening.
Last is the radiator - again get a 2nd opinion or even remove it yourself and get a clean out. Make sure the radiator cooling fins are not deteriorated either as these help with the cooling.
102389
Reply By: Peter 2 - Monday, Mar 14, 2005 at 18:42
While the outside of the radiator may look clean aqnd be able to be seen through it is amazing how much crap can get stuck in it externally, never mind the internal blockages.
Troopies especially 2H powered ones do run hot as at road speeds, 80 -100kph there is bugger all airflow in the engine bay in standard trim BEFORE the bullbar, winch,
driving lights, bug screen and anything else is fitted to the front further restricting airflow. Never mind the extra heat from a turbo, that is why the last 2h powered ones had an extra grille on the passengers side and a box around the battery to stop it cooking.
My NA 2H powered troopy would run hot in summer, on one trip out west in Sept I removed the grille and badge which enabled it to cope as long as I stayed in 4th gear rather than 5th. The rad had been serviced/cleaned every year before long trips too.
102401
Reply By: Freeman4wd - Monday, Mar 14, 2005 at 19:02
Hi Kristy,
After numerous checks, my overheating problem ended up being the thermostat. This was the first thing that was checked and it was opening up, obviously not opening enough. But keep the following fact in mind:
Exerpt from a
well known turbo supplier -
"REMEMBER THIS DIESEL SAYING- ‘Rich is Hot (more Fuel)….Lean is Cool (less Fuel)!!
Fact- It‘s simple physics. Pressure and volume are relative to each other. A turbo running higher boost gets higher volumes of air to an engine than the one running lower boost. The higher the boost the more air volume! A turbo is only an air supply device. Boost pressures used in turbo charging are relatively low and don’t generate much heat if any. If we kept compressing the air to a couple of hundred PSI though, air would soon heat up. It still stands that fuel makes the heat in the
equation!! Loads of fuel means loads of heat. A correctly matched turbo spins up fast so as to keep a nice lean mixture down low and to get a torque increase early in the rev range (a lean mixture is cool and clean in a diesel!!). As we know, diesel engines produce maximum torque at low engine revs so we need a turbo to be at maximum boost at those low engine revs. What's happened now to the ‘large low revving turbo‘? Not much, until the engine revs get up high. Too late for the boost to arrive at high revs! In fact if the boost is kept low and the turbo spins up slowly, the fuel and air mixture can be quite rich in the low to mid working range of the engine. ‘Rich means heat in a diesel‘. That’s why using a large ‘cool’ turbo charger is a fallacy! With the high revving diesels of today, a turbo needs to boost early and hold the boost through the large rev range. "
Regards.
Frank
102403
Reply By: Member - Royce- Monday, Mar 14, 2005 at 23:28
I know the problem. Drive you crazy. I went through every option I could think of apart from replacing the motor. I've got two 75 series cruisers. The Supa Trupa and a trayback. Under heavy load towing and loaded down the 2H trayback never over heats NEVER! The Supa Trupa ALWAYS overheats on any hot day or up a
hill or standing in traffic.
Well... I finally decided that it had to be a micro crack in the head and had that done.. cost mega-bucks. No use. ....
I even considered putting a little radiator further back underneath the body, mounting a electric thermofan and a
water pump to feed it. I was going to incorporate so much damn copper piping that simply the volume of coolant going through the system would keep the rotten thing cool.... I was gunna... I was gunna.... then the motor died!
So I'm currently fitting a 1HZ motor with matching gearbox..... yep replacing the motor.
ps.. the Supa Trupa was turboed DTS, but overheated before and after. I'm planning a trip up the middle to
Darwin later this year.. October... should be hot enough to try out the new donk.
102457
Reply By: ianmc - Monday, Mar 14, 2005 at 23:52
Oh what a feeling!
Well couldnt help that one!
Would an oil cooler help? My ole TD Triton has an engine oil cooler, standard I think, & never had any signs of overheating & rarely top up the coolant. Maybe thats the answer, maybe not!
102460
Reply By: Member - muzzgit - Tuesday, Mar 15, 2005 at 00:21
One option may be to look at one of those electric
water pumps advertised in 4WD Monthly. They automaticaly adjust coolant flow based on
water temperature. The editors little suzi with the holden V6 donk uses one with good results. One of these with a higher volume radiator may be the answer.
As for the gentleman who mentioned Exhaust Gas Temperatures (EGT), He is right. Most fuel injection mobs should be able to do a test on a dyno for that.
102464
Reply By: Member - Chris (SA) - Tuesday, Mar 15, 2005 at 01:40
Had the same problem Kristy. You should be aware that the temp guage always should be about half way as
My solution was to replace the radiator, hoses, thermostat , recon the fan coupling and had it done by a good, reputable workshop (if you're near
adelaide, it's in holden
hill).
After some $700, it now works fine and has never missed a beat towing my camper trailer anywhere in any heat.
I have bullbar and lights fitted as wll and now the problem is solved.
102467
Reply By: Member - Phil G (SA) - Tuesday, Mar 15, 2005 at 21:57
Overheating 75 series with aftermarket turbos commonly get discussed.
Check thread 20572.
As I understand it, a bigger, better radiator helps.
BTW if yours is a '91 model it will have the 1HZ.
Also out of interest, the factory TD 79series have not had this problem. Had
mine in soft sand at 40 degrees at the weekend without the temp gauge moving. I know they have a bigger 3-stage fan as
102588
