Nokia 6385 CDMA Issues
Submitted: Saturday, Mar 19, 2005 at 15:26
ThreadID: 21353 Views:2827 Replies:7 FollowUps:1
I've just changed from GSM to CDMA on a Nokia 6385, I haven't been out of the city with it yet but it rarely shows full signal, usually 2 to 4 of the 7 bars.
Metro Melbourne I've seen full signal and once at home in the driveway and once at work.
Currently in Palm Cove, just north of cairns with 1-2 Bars.
Just thinking that if it shows this lttle signal while in relatively populated areas, how well is it going to go out bush.
Also, can anyone suggest the CDMA phone that is likely to have signal when others do not?
Any help or suggestions most appreciated.
Reply By: BenSpoon - Saturday, Mar 19, 2005 at 15:34
I've found the same with mine- But then I've also found the signal strength displayed isnt always an indication of how a call will go.
Cruising from NW WA to the SW, the most part of the trip my phone (CDMA) was showing "Searching for coverage" whilst my mates GSM had one or 2 bars signal. When I needed to make a call though, it came good and had no problems.
CDMA without a doubt has improved range in the bush. I work at a few mine sites that are 100km from the nearest country road, and GSM is non existent. CDMA however works perfectly.
I also recall seeing full signal strength last time I was in the suburbs of Perth, and now even with the car kit and external aerial I dont get full strength, but calls are fine and in all the time I've had CDMAs, I only recall 1 call being dropped.
AnswerID: 103081
Reply By: Glenno - Saturday, Mar 19, 2005 at 16:17
I live in Ashgrove about 5km's out of Brisbane CBD and only get 2 bars on my 6225. You wouldnt know unless you look as the signal quality is still excellent.
I just purchased an external antenna and coupler to hook onto the phone. Keen to see how it goes around town and as we head out to camerons corner over easter
AnswerID: 103088
Reply By: Bob - Saturday, Mar 19, 2005 at 17:12
The Nokia 6385 has an external antena port.
Grab a 7dba external antena and hook it up, worked wonders for mine.
You will also need a patch lead from the phone to the antena cable.
I was pulling in full signals while others nearby were getting nothing.
AnswerID: 103092
Follow Up By: hl - Saturday, Mar 19, 2005 at 17:52
I have had the 6385 for a few years and it works fine. Don't worry about the signal display. It doesn't mean much.
I drove from Dubbo to Broken Hill a few weeks ago, and coverage was almost continous!
I couldn't believe how well it worked in more than 100k form the nearest town.
I do have a car kit as I also have GSM phones. The Car kit for the Nokia 5110, 6110 series also takes this phone.
FollowupID: 360687
Reply By: Muddy 'doe (SA) - Saturday, Mar 19, 2005 at 18:16
Hi jrw
I recently got a Nokia 6225 CDMA phone and have noticed that the signal strength and call quality are much the same in the city as away from it.
The big difference is that GSM just falls away when you leave town but the CDMA lasts quite a bit longer.
Muddy
AnswerID: 103104
Reply By: fisho64 - Sunday, Mar 20, 2005 at 02:29
As said dont worry too much what the screen says. Ive had good coverage up to 200 miles out to sea at various times, and coverage has ALWAYS been better than GSM. Ive had an LG(crap) and Kyocera (endless probs) Nokia 6385 has had probs too and not up to their previous "best phone" standard but it was their first CDMA.
Electronics bloke tells me that with an external aerial on a CDMA or GSM, if the cable is more than a couple of meters long, you could attach the Eiffel Tower to the end of it and it wouldnt make any difference as the transmitting power of less than a watt will only go that far up it
AnswerID: 103138
Reply By: duncs - Sunday, Mar 20, 2005 at 21:54
I live in Broken Hill and have a 6385. The car kit makes a huge difference. There are still a few places around where we run out of coverage but generally it is excellent. I run an 8db dual band antennae for the wifes GSM as well but in a single band I know of people running 12db. Go the biggest number you can get.
Duncs
AnswerID: 103217
Reply By: old-plodder - Monday, Mar 21, 2005 at 09:36
I have an old LG cdma. About 5 years old now. Always prefer it to gsm.
Doesn't often show full signal, but it did surpirse me when out near Quilpie and I had a phone call 94k out of town (as the crow flies) on 2 out of 7 bars. GSM only has a range of about 37k due to the signal carrier.
Found the same thing around the city when in basements etc. Not full reception but works well on lower signals.
AnswerID: 103259
